![]() | Home > Technical (L322) > Air Suspension inactive ...... |
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 ![]() ![]() ![]() |
Suddenly getting this error (recorded from EAS activate device) - battery fine and appears to clear itself after a while but has happened each day this week when I start the car.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35499 ![]() ![]() |
search "air suspension inactive" [with quotes] ...there's loads re this... ... - .- -.
Thanks GOG! - thats what I was looking for - had a thought it maybe a sensor rather than the normal EAS stuff. I will check them this weekend. "On first name terms with my local Dealer......now."
Had a search but can anyone tell me if it is possible to test the height sensors on the l322? It would seem that it is a sensor issue as the eas inactive goes away when you get to motorway speed and the car correctly drops to the right setting, when you slow up it gets confused and the error appears. I don't have any of the flash diag tools. I do have access to the SE to view the ODBII data if that would show it. "On first name terms with my local Dealer......now."
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
Had this fault when I had hole in airbag.
Had one of those before so did check to see if that was the case again but doesn't appear to be. Is there anyway to get a decode of the error I posted or is it generic and what I have from the eas activate tool is all I can get? "On first name terms with my local Dealer......now."
This post more or less covers it: Either airbag or faulty sensor. If you don't think it is airbag, try changing the sensor first (much cheaper!!)
Thanks Joe90 - the fault is the same so looks like a height sensor. If dan is reading this can he tell me how much they are? "On first name terms with my local Dealer......now."
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Sensors are around £25 per corner |
Has anyone done a photo gallery of how to get at them / check them before I start trying to find my copy of Rave? Sure its a sensor now as at one point today it thought it was in off road mode on the warnings but the lights said normal then it changed back. "On first name terms with my local Dealer......now."
No photographs but more or less self explanatory when you see them
Many thanks all, last question - how can I test the sensors as I don't know which one is faulty? Short of it being obviously broken(snapped) is there a test I can do? Are they resistance based or digital signal to the bus? "On first name terms with my local Dealer......now."
If your vehicle has the original sensors they will most likely all be on the way out. The connector where it bolts onto the suspension corrodes and the rubber splits.
I would expect they are original - thanks for the info, will order replacements. "On first name terms with my local Dealer......now."
