Home > Maintenance & Mods (L322) > Rear lights conversion issue
JohnRR
2007 Range Rover Vogue TDV8 Zermatt Silver
Hi,
I bought a set of 2010 Led rear lights from eBay but I am having issues with swapping the units out. Basically they don't seem to fit. The sockets that the original lights use do not seem to be compatible with the new units. The spikes that go into the units on the new lights stick out much further than the originals. Am I missing something? Everything I had seen had suggested they were a straight swap the video up on youtube about changing them makes it look like mine are how they are meant to be so I am concerned there is something wrong with the units I have bought. Any help would be greatly appreciated.
Post #135532 11th Aug 2012 7:52pm
SteveMFr
Site Sponsor
Yes, you need to drill new holes and install new grommets.
Do a search. There is info on the board.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #135537 11th Aug 2012 9:14pm
Re: Rear lights conversion issue
Im not far from you if you need them installed and wired so they work correctly... As you cant just plug them in...
http://cam-tech-landrover.co.uk/
Craig Thumbs Up
Post #135674 12th Aug 2012 10:37pm
