![]() | Home > General > Strange Question?? |
The Hitman Member Since: 28 Jun 2011 Location: Greenhithe Posts: 30 ![]() ![]() ![]() |
Anyone know how much weight the bottom tailgate can take...... it is for a good reason (and not for anything else which may spring to mind |
Read on another forum that someone had 400 kilos on it approx 850lbs |
![]() Ok thanks will have to dig a bit deeper.... just looking to see if the bottom tail gate will take the weight of a couple of ramps and loading up my misses mobility scooter as and when she needs it ![]() perhaps we could then try a couple of italian job trial runs ![]() ![]() ![]() |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
Buy two new support straps before attempting, as these get rusty after a few years and can give way under load (as told by "big" stan |
Duckworths Dan does them at a reasonable price and they are easy to fit if you have the right torx head.[/quote]
The scooter weighs 109kg (241lbs) including the 2 batteries so in theory the tailgate should take it........ just wasn't sure as also need to take into consideration the ramps etc but might just get a couple of new tailgate straps to be on the safe side |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
you should have no problems with that weight, bearing in mind it is only ever going to be for a short space of time not continual load.
Thanks Stu
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
as joe90 kindly pointed out, my tailgate took both the combined weight of me and the wife [26stone] until one of the straps broke but that was due to corrosion so you could safely add a few more pounds.. ... - .- -.
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
Interesting to see that Stan is happy to post his wife's weight but not his own. |
and i quote ''combined weight'' |
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 ![]() ![]() |
Can't wait to see the video of you driving it up the ramp into the back |
