![]() | Home > In Car Electronics (L322) > ELM Bluetooth OBD + Torque (Android) |
Hi,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35659 ![]() ![]() |
they do sound pretty good neil, but i seem to recall reading somewhere that if you leave the bluetooth unit in the obd port permanently, it 'might' drain the battery.. ... - .- -.
Hi Stan,
Last night did a standing start with DSC on - 0-60 9.1s 1/4m 17.1, 310hp at 3650rpm.
Torque shows coolant temp. I'll have a look to see if has the transmission temp. Basically if the PID's are there for it, it will read it.
when closed, the port cover does indeed switch off the supply neil.. |
Oddly the Freelander doesn't have this requirement (the pins...) Land Rover Addict
from memory, there have been a few members on the forum that have had battery drains and it was down to the obd port cover being open.... ... - .- -.
Hmmmm interesting. Bear in mind that the OBD cover on the 2007MY -> interferes with the accelerator (well your foot at least!) so I'm guessing these were pre 2007 vehicles (or people with tiny feet!). I wonder why the RR needs to be told to shut it down when other cars do not. Land Rover Addict
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 ![]() ![]() ![]() |
Which ELM would you recommend?
ELM : http://www.ebay.co.uk/itm/261043849303?ssP...1439.l2649
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
Did the OBD module not get in the way of your accelerator foot? Also how did you launch your FFRR? I can't decide if I just floor it and hope the auto-handbrake lets go, or try using the old footbrake + accelerator trick (american style). ![]() 07 Supercharged - Still breaking her in! Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html 18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html |
I just floored it. Will have another play again on a better road.
