![]() | Home > Maintenance & Mods (L322) > 2010/2012 Facelift Conversion with parts list & numbers |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
Added some more info on rear light modules, PDCs and looms. Tom
flow11234 Member Since: 08 May 2013 Location: pa Posts: 36 ![]() ![]() ![]() |
looking to buy headlights from ebay !!!!What is the difference between the sport hse headlights and the hse size wise will the still fit. |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 ![]() ![]() ![]() |
Reagarding the headlamp washers, my car has the 2006-9 facelift but the guy I bought it from never had the washers connected or adapted.
Sport headlamps will not fit the FullFat.
Bozzy1954 Member Since: 04 Jan 2012 Location: Derbyshire Posts: 27 ![]() ![]() ![]() |
Hi, I gather from the post that the metal bar on the 2003 (the one the bumper bolts to) will have to be replaced. |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Yes it does.
I thought so, just when you think you have everything.
Just updated the headlight wiring info, made a test conversion loom without having to cut off the original car plug that works a treat. Angel eyes flash a few times on start up but this is the cold monitoring which I can switch off with the IID tool Tom
mmiata Member Since: 12 Jul 2013 Location: Budapest Posts: 104 ![]() ![]() ![]() |
Hi,
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
^^^ I have the bar you need for sale, in silver, no use for it |
Thanks! how much would you look for it? |
Would it need to go to Hungary? => answer via PM please l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
[quote="duckworthparts"]send me the full list of what you want inc part numbers (i'll double check they are correct), looking over those prices quickly i'll be able to do cheaper..
^^^Hi, you have to go "All-in" to get the 2012 look, it is not possible to simply change the headlights as the grill and bumper shapes are really different from the previous model. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
