Home > General > Help - broken down in Calais!
WelshCH
Switzerland 2007 Range Rover Vogue SE TDV8 Stornoway Grey
Hi All
Am currently broken down on a road in Calais - drove up from Geneva today without a problem and car was serviced yesterday! Car is 2007 TDV8 Vogue SE - stopped at a fuel station and now car won't restart - engine doesn't turnover at all. Problem is that I can't get the glovebox to open to access the car manuals etc (electric power for all things seems to be ok) - does anyone know how to open the glovebox any other way than pressing the button with the arrows on please?
Cheers
Aled
Post #129851 7th Jul 2012 8:44pm
dont know about the glovebox but if it doesnt turn over it could be the battery.. ... - .- -.
Post #129856 7th Jul 2012 9:12pm
ebajema
Can you get a cheap voltmeter and check the battery voltage ?? Also, disconnect the battery for 10 mins to reset everything. Are you sure your key is OK as in the battery in it is fine (does it open and close the doors ??). MY 2010 5.0 SC Galway green and sand interior!!
Post #129859 7th Jul 2012 9:22pm
mzplcg
I would bet good money your alternator's goosed. Mine did EXACTLY this, on my way to a job interview no less. No warning, no red light, just a crap load of errors followed by changing to 4th gear and staying there until the last thing to die was the fuel lift pump, which was game over.
Get the bonnet up, get some jump leads on it and you should have enough power to open gloveboxes etc.
You could also disconnect the battery earth lead and get another car to charge it up a bit with jump leads. Would at least get you back to British soil to get it fixed.
Bear in mind the battery will be so discharged that even the hazards won't work. Utterly pancaked. Alternator on a TDV8 is an OK-ish job but does need radiators out etc. Not a side of the road job.
Best of luck.
Dom.
Post #129951 8th Jul 2012 6:49pm
bozmandb9
Have you double checked it is correctly in Park? Even if it appears to be, move it into drive, and back into Park, if you're getting nothing at all, then it's probably that the car believes that the safety criteria for starting the car have not been fulfilled. It's happened to me before! Range Rover-less at the moment - Pining!
Post #129952 8th Jul 2012 7:12pm
mzplcg
Wouldn't stop the gloveboxes opening Boz. Only lack of electrons will do that.
Post #129954 8th Jul 2012 7:29pm
bozmandb9
Missed that when I read about the problem, wow, does the glovebox really need current to open? Shocked Range Rover-less at the moment - Pining!
Post #129959 8th Jul 2012 8:01pm
rayc
United Kingdom 2007 Range Rover Vogue SE TDV8 Rimini Red
If you get really stuck. Send me a pm. My mate lives in Calais and has a very good garage on the outskirts that may be able to help 08 model TDV8 Vogue SE Rimini Red/ parchment. 04 TD6 Vogue Oslo Blue / parchment
99 Model 2.5 DSE Rioja Red / lightstone
97 BMW M3 Evo Convertible
plus a few more!
Post #129960 8th Jul 2012 8:09pm
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Yes unfortunately for you from 07MY the glove box button is electrically powered.
Post #129962 8th Jul 2012 8:11pm
Ukdave104
United Kingdom 2011 Range Rover Vogue 4.4 V8 Rimini Red
But in his post he says that "electrical power for all things seems to be ok" Confused
2011 Range Rover Vogue 4.4 TDV8, Mine........ALL mine.
2012 Freelander 2 HSE SD4 - Mrs UkDave's new toy
2007 Freelander 2 GS TD4 - gone
2010 Discovery 4 XS - gone
2008 Discovery 3 HSE - gone
Post #130279 10th Jul 2012 3:25pm
Flashman
Is he still there? Tom
Current Drive
Previous Drives
Post #131053 14th Jul 2012 11:58am
it would be nice for the OP to let us know whats happening.. ... - .- -.
Post #131100 14th Jul 2012 7:56pm
mjdronfield
he'll be on one of those bicycles now, with the basket and the onions and a beret.................. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #131113 14th Jul 2012 8:46pm
WelshCH
Hi All
Apologies for the delay in updating but I just got back from my holiday and was reunited with my car in Switzerland.
We ended up leaving the car in Calais, going through the tunnel in a French taxi and then on to Gatwick where we got a hire car for our time in the UK. On the return journey, we got a UK taxi across on the ferry and then on to Lille, where we picked up another hire car to drive back to Switzerland. None of the dealers in Northern France had availability to look at the car and so it was returned to my local dealer in Switzerland. It turns out that the alternator went and so the battery. Both now replaced and all now seems to be fine. Thank you for the responses / advice.
Cheers
Aled
Post #132551 23rd Jul 2012 4:44pm
Flashman
Glad to hear all is well! Tom
Current Drive
Previous Drives
Post #132556 23rd Jul 2012 5:11pm
