Home > General > 'Clunk'...... No Start......
JMC
TDV8 Vogue - Key in ignition, turn, 'clunk' from engine bay but no start. Evil or Very Mad
I can hear what sounds like the starter relay engage, but nothing else. Turning off and on again usually resolved the problem. This has happened almost every time I go to start the car in the past couple of weeks. Yesterday, I had to turn the key off/on three times to get the engine started.
I'm guessing either a duff starter motor or just a slightly loose cable in that region. Anyone else had this issue?
First service will be due about February so I'm sure it can wait........ Whistle The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #8784 26th Nov 2009 8:48am
Macdaddy
2003 Range Rover Autobiography 4.4 V8 Java Black
Sounds like a sticky starter.
In the old days you could put the car in gear and rock it which would free it.
Not quite as easy to do with something that weighs 3 ton tho! TDV8 HST Sport **Current**
4.4 V8 Autobiography and 22" wheels **Gone**
Post #8785 26th Nov 2009 9:04am
JMC
Yes, I remember the 'old days' too...... Big Cry The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #8789 26th Nov 2009 9:20am
Are you referring to the FFRR or JMC ......... Rolling with laughter Bow down Bow down Thumbs Up
Sorry couldn't resist it ....... Thumbs Up Thumbs Up
Post #8792 26th Nov 2009 9:26am
JMC
Have you seen me? Shocked Laughing The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #8793 26th Nov 2009 9:28am
Vogue
could be a loose cable on the starter or solenoid. We have this frequently on tractors. If the cable terminals are not tightened down fully, there is enough power getting through to engage the starter and give a jolt, but not enough through the contact to turn the engine - on a tractor you can wiggle the contacts and turn the key and it always works, bit more difficult on a RR unless you have really really long arms or a handy passing monkey who will oblige Cool
Post #8801 26th Nov 2009 10:21am
