Home > Technical (L322) > reverse camera will not activate after 2012 conversion
highfellzippy
United Kingdom 2015 Range Rover Autobiography SDV6 Montalcino Red
no
but its been off and camera changed
usually when camera fails you just get a black screen
Post #128768 1st Jul 2012 3:47pm
it does sound like the wiring somewhere could be broken ...you could download/view RAVE [link in wiki] and try and follow the wiring ...i would concentrate in the spoiler area as that's the only place that has been messed about with...
as for the dvd problem, Question ... - .- -.
Post #128769 1st Jul 2012 4:12pm
JustinP
Can you view the camera using the 753 diagnostic mode?
Click the following link if that means nothing to you Thumbs Up
http://www.fullfatrr.com/forum/topic2243.html
Post #128779 1st Jul 2012 6:10pm
highfellzippy
now 5 days at main dealer with no joy
i dont think they are going to solve it useless Censored S
Post #128984 2nd Jul 2012 4:38pm
muddycharles
United States 2008 Range Rover HSE 4.4 V8 Bonatti Grey
Update - 8 hours with Landrover tech support
Turns out they had to reset the instrument ecu and engine ecu to the "generic" one for my model year. This was because of the changes that I had made to the CCF files in the ECU and the camera simply would not engage.
Resetting these to factory spec made the difference. Camera works now.
I would suggest that the right path here is to download and save the current CCF files, and go compare them to a RR that is working - you will see what the problem is then.
Im also guessing that you have a region code error with your DVD? Maybe the unit thinks its in a different DVD region?
I have learned my lesson with these cars - back up any data file before editing as really bad things can happen. 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #128986 2nd Jul 2012 4:44pm
