Home > Technical (L322) > Which other cars have the FFRR type auxiliary cabin heater
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
My VW Touareg had the diesel heater as many cars do now as standard figment. The idea is only as an aide to heat the thing up quicker! A large diesel motor takes an age to produce hot air otherwise. All you have to do is find your nearest Webasto fitter and hand over about ฃ700 of your hard earned pound notes and they will fit the timer module etc. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #127481 25th Jun 2012 7:01am
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
A1GSS wrote:
PaulB wrote:
My X5 had the exact same heater
Hi Paul,
Which X5 was it? And was it a timed operation and keyfob remote, like the FFRR? Or just an engine heater like the D3?
Thanks Thumbs Up
Now you have got me thinking!!
It was a X5 52 plate.
I fitted a remote switch from maplins which enabled me to activate it from inside my house.
Im not sure if it had the timer on the dashboard Confused
Post #127572 25th Jun 2012 4:14pm
A1GSS
I think that's just the heater for the coolant and block. I'm looking for a cabin heating option ie where the fans come on... Very Happy Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #127573 25th Jun 2012 4:31pm
it was an option on the BMW's i think. It was a Webasto aux heater which was fitted to the cars with the 3.0 diesel, it was fitted as an engine heater as standard but could be upspecced to a cabin heater at mfr.
My e39 had one which was a block heater though the instructions were there for the timed climate in the hand book, my e61 had all the bells and whistles and could be timed on.
Never used it. There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #127625 25th Jun 2012 9:51pm
SteveMFr
Site Sponsor
The X5 and the E39 are more or less the same as a RR electronically (at least the early L322 and E53 are). So the same procedure to activating the park-heat function goes for BMWs as for RRs. The IIDTool will even do this on an X5... Smile
Graham, are you looking for a new car? (Not sure I understand what you are asking for).
Webasto FBHs as park heaters are relatively common in Germany. There have been strict laws in place against letting a vehicle idle to warm up for a long time. So, if you want a toasty car in the winter, you don't have much of a choice. Either FBH or electric block heater. I am relatively sure that all diesels with a FBH as an auxiliary heater have a park heat option - even if the manufacturers make it hard to unlock this feature. Mechanically and electronically it is the same unit in both functions, so it hardly makes sense not to have this programmed in.
Webasto also makes FBH's (and retrofit kits) for petrol vehicles. Kit cost is roughly €1200-1400 and installation another €500-800.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #127632 25th Jun 2012 10:06pm
A1GSS
Hi Steve, Yes - considering my options. I sold the FF a month ago, looking for a replacement that's maybe cheaper to buy and run, and would like to retain the toasty cabin feature... Graham
____
Post #127644 26th Jun 2012 6:02am
