Home > General > Sill scuff plates
Robhibbert
2012 Range Rover Vogue TDV8 Santorini Black
Sill scuff plates
Hi all
I want to change the sill scuff plates on my RR but don't know how to remove the old ones. Any help please?
Post #8522 19th Nov 2009 5:37pm
speedymarktd6
have you tried pulling it hard , till summink happens Thumbs Up Thumbs Up onto no6 Range Rover
Everyone needs a hobby
Post #8525 19th Nov 2009 5:47pm
Warm them up with a hairdryer for 10 minutes or until you can start prising them away. You just need to heat the adhesive tape underneath you see. Likely that some will stay on the paint and it's a bitch to get off!
You just need elbow grease! Discovery 4 HSE
Post #8527 19th Nov 2009 5:51pm
daveo
hi, what are we trying to remove, the tred plates or sill scuff plates, i just removed my tred plates to have them polished, they have to be stripped as they are anadised but when polished come up lovley, they are held down with plastic clips and need a good tug to get them up as were the sill covers are stuck down,
daveo
Post #8529 19th Nov 2009 6:18pm
Robhibbert
It's the plastic tread plates
Post #8531 19th Nov 2009 6:48pm
daveo
then as RRUK said warm them up with a hair dryer and they will come off.
Post #8532 19th Nov 2009 6:51pm
Robhibbert
Cheers guys I'll try the mrs' hairdryer!
Do you think this might remove some glue that is on the doors from where the plastic door protectors used to be?
I got most of it off but there is a tiny annoying bit left on there!
Post #8533 19th Nov 2009 6:55pm
nbunney
Try T Cut, that's good for getting rid of glue.
Post #8554 19th Nov 2009 9:41pm
ENVOY
United Kingdom 2003 Range Rover Vogue Td6 Java Black
Thinners that will sort out the sticky stuff
Post #8556 19th Nov 2009 9:42pm
