Home > Technical (L322) > Vibration at 55mph
ukwizard
England 2006 Range Rover Vogue Td6 Bonatti Grey
Vibration at 55mph
I wonder if anyone can help.
I have noticeable vibration through the car at almost exactly 55mph, speed up to 57, or reduce to 53 and the vibration stops. The only other thing I would add is above 55 I would say the steering feels quite light, like there is too much power assist.
Ive read about prop shafts causing vibration, so maybe that is the issue, but its very specific to the speed, everyone in the car knows when we are cruising at 55!
Its on an 06 TD6 RR, I had a 02 4.4 before and never noticed the light steering on that (just electrical issues!) or the vibration.
If anyone has any recommendations for a garage in the Manchester area that they use for their RR they would be very welcome as Im not that happy with my current garage, I'm not sure they see that many RRs and their suggestion at the moment is to change the tyres which I guess might help, but again I'm not that sure (which is why I'm asking here!!!)
Thanks
Andy
Post #124862 3rd Jun 2012 7:41pm
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
Have you lost any balanching weights off your wheels? Recently had new tyres fitted? Put your spare wheel on the front?
Maybe try wheel balancing and tracking first as the cheaper options? These can cause vibration at certain speeds..
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #124865 3rd Jun 2012 8:12pm
i agree with dave, have your wheel balancing checked.. ... - .- -.
Post #124870 3rd Jun 2012 8:49pm
ukwizard
Thanks.
Post #124873 3rd Jun 2012 8:55pm
^^^^i agree with the posts above, i kept losing weights off my 19" wheels.
Get them to re balance with stick on weights, less likely to come adrift. There is nothing that can't be fixed with a hammer😜😜
Post #124877 3rd Jun 2012 9:17pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Maybe the torque converter.
Does it sound like your travelling over a cattle grid?
Post #125523 9th Jun 2012 9:12pm
Hoveronly
United Kingdom 2006 Range Rover Vogue SE 4.4 V8 Zambezi Silver
Mine started doing this yesterday and when I had checked the weights, one had been lost. My car does however also suffer from the railway track vibe and pre 5omph engine hunting.
Post #125528 9th Jun 2012 9:47pm
ukwizard
No noise as such on mine, just vibration which could even be described as shaking more than a buzz.
Away at the moment so I can't get the wheels rebalanced until next week, but I'm going to give that a shot as there are visible weights on three wheels, but none on the rear offside so it's probably the culprit.
Thanks
Post #125536 10th Jun 2012 5:28am
daveym
United Arab Emirates
Is it gear hunting at around 30-35mph? The reason i ask is that mine had the cattle grid vibration at 55mph with gear hunting and it turned out to be my torque converter.
Hopefully this is not your issue.
Post #125543 10th Jun 2012 8:52am
Thanks
If its vibration through your seat you can feel then its the rear balancing. if shaking through the steering wheel then its fronts...
Craig Thumbs Up
Post #125550 10th Jun 2012 9:08am
mjdronfield
If its not wheel weights, 55mph is when the servotronic power steering changes steering assistance, and it is not unheard of for the valve in the steering to be a bit iffy and cause light steering and a vibration through the steering wheel.....
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #125551 10th Jun 2012 9:11am
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
Have a read of this thread: http://www.fullfatrr.com/forum/topic6961.html
From my understanding based on other peoples experience:
Bad vibration:
Torque converter
Injectors
Low to medium vibration:
Wheels
Brake disks
Post #125552 10th Jun 2012 9:14am
Hoveronly
Tried the G-box flush etc but though better, is still annoying. Car has only 63k on it so a bit disappointed really. Just read through your suggested thread mrd and will be getting the T/C done asap. Anyone recommend where I can get one done in the Salisbury/Southampton area?
Cheers
Post #125578 10th Jun 2012 1:22pm
Hoveronly
Just has a quote for replacing the T/C of £675 inclusive from eBay 'gearbox-man' (Barnsley). Seems reasonable but a bit North for me.
Post #125580 10th Jun 2012 1:37pm
mrd1990
Although it's highly possible, don't bank on it being the TC
You could save money by having land rover diagnose the problem then get an independent landy garage to fix it Thumbs Up
Post #125608 10th Jun 2012 6:20pm
