Home > Technical (L322) > Fuel injection problems TD6 |
Markdoyle124 Member Since: 26 Nov 2013 Location: Portsmouth Posts: 6 |
Hi there, did you ever find the cure to your problem? Mine sounds exactly the same? Was you able to change the fuel pressure control valve yourself? Thanks |
20th Jul 2014 11:13am |
the-craig Member Since: 21 May 2012 Location: Surrey Posts: 2 |
Hi, the fuel regulator ( In the end of the fuel rail ) is very easy to change, just remove the pollen filter casing to gain access.
20th Jul 2014 8:54pm |
Thanks for that sounds like it's a pretty common fault now I looked it up, thanks for pointing me in the right direction, all makes sense now, just need to see if I can get the loom for £45 still?? 😁😁 cheers!! |
25th Jul 2014 10:58pm |
