![]() | Home > In Car Electronics (L322) > 2003 Vogue Stereo problem.... |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7879 ![]() ![]() ![]() |
If it is the BM54, the upgrade from Baris may fix the issue as well.........give him a call ? 2011 Range Rover Vogue SE 4.4 TDV8
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
Its the blue plug on top of the right hand unit - it will be corroded. Mine did exactly the same so I took it off cleaned using degreaser on the plug and anp pins then a light film of WD40 and put it back together - now works fine |
Pedrochellie Member Since: 23 Feb 2012 Location: Surrey Posts: 82 ![]() ![]() ![]() |
Thanks Guys, I have contacted Baris and will be doing the upgrade so hopefully that will be the end of problem, although I will check the plug mercs, thanks for that |
Quick update - the problem has disappeared...........all working as it should |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
I had a similar problem once - all exactly the same - and then the Sat-Nav crashed, rebooted and all was lovely again. |
I have an issue where the Radio cannot find any station as if the arial is disconnected does anybody have experience of this issue? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35533 ![]() ![]() |
could you have actually knocked an aerial connection gary.. ... - .- -.
Nor mean but previous owner may have. I just wondered if anybody had ever had similar symptoms?
Very rarely the antenna amps go on the fritz too.
OK will have a look. It odd that it simply does not locate any stations? |
you've probably done it but what about a battery disconnection? ... - .- -.
done it. |
Oh boy - here we go again!!
