Home > Maintenance & Mods (L322) > digital upgrade - Problem??
ggdtr5
2004 Range Rover Vogue Td6 Zermatt Silver
Just bought a TV digital upgrade unit part no 6 966 696 to replace my analogue unit. - I thought it would be just plug and play, the installation was easy just replaced one for one all the connections were the same.
When I first switched it on I could see some digital channels but the mute was on so I pressed the rescan buttton and now no channels at all !!
Argggg ... What am I doing wrong?
Program is set to AV and there is no option to change this - anybody know what this is?
TV format - what should this be? -I have tried several different options PAL, SECAM etc still no channels found.
my car is a 2004 RR - pre touch screen
the old analogue unit was YIL 000023
grateful for any help/advice
regards Graham
Post #123210 23rd May 2012 9:55am
With digital, there is no pal,SECAM whatever to set up, just ignore all those settings. Before you try anything else, drive to somewhere else and try it again. They need a decent signal to work. Mine will not work in my drive but does work at the end of the road... Worth a try. Previously..
Post #123211 23rd May 2012 9:59am
ggdtr5
System working now - just needed to move the car to get a signal......Simples.....
Thanks for the advice
regards Graham
Post #123215 23rd May 2012 10:26am
cleughy
England 2004 Range Rover Vogue Td6 Santorini Black
what did the tuner cost?
i'll be lookng later this year after i get over paying for my gearbox Crying or Very sad
cheers
steve
Post #123257 23rd May 2012 2:41pm
ggdtr5
I bought the Unit on ebay - just over £400 - ouch, but probably cheaper than a gearbox!!!
Gearbox!!!! oops how many miles have you done? - I have done just over 70k they say that any time from now the gearbox goes - up here they are getting them done for around 2.5k.
regards Graham
Post #123261 23rd May 2012 3:12pm
cleughy
56kmiles, it was the pump, i'm a bit Censored ed about the turn around as the company doing the pump have "forgotten" to make it the most important job in shop so its turned into a 2 week job. Cost wise i was quoted £1700 & vat so i'm hoping to know a few quid off for the time its taken.
steve
Post #123265 23rd May 2012 3:33pm
