![]() | Home > Technical (L322) > 2 front air suspension bags burst together! |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
sounds a bit funny that both have gone at the same time, what are the symptoms... V8 facelift Range Rover Autobiography 22" wheels.
SSSL322 Member Since: 09 Apr 2012 Location: Surrey Posts: 15 ![]() ![]() ![]() |
Well it currently looks like an american low rider at the front with it a** in the air!!!!
i am sure i read some thing about putting the car into access mode when jacking it up, not sure if thats right, but have the garage taken responsibility, they usually pop when they go, are you sure its not the air line to the bag, have you seen the bag split. V8 facelift Range Rover Autobiography 22" wheels.
Heard the pop when they jacked It up can't see it as the cars literally on the floor now!
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
When jacking my car using the scissor jack, I put the car in off road height to save jacking the entire suspension travel length. I also jack with one door open to prevent the car trying to re-level itself.
Thanks Justin
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
I don't adjust my suspension before jacking the vehicle up |
ahh yes,it might of been in the off road position, i know i read it some where and yes it was something to do with the height sensor
daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201 ![]() ![]() ![]() |
New air struts can be purchased for about £215+ vat warranted for 2 years, pretty simple DIY job, more info on this thread.
Thanks All
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
I'm sorry but I fail to see how a garage jacking your car up can be responsible for an airbag popping! The car is made to be jacked up in any suspension mode! If you have a weak bag and it just so happens to pop when it gets jacked up then how can the person jacking it be held responsible really!
Thanks for your feedback Craig.
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 ![]() ![]() ![]() |
I can see how they've managed to over extend the suspension travel jacking up the car thus popping the airbags, not jacking up via the axles and using a two post ramp for example. I've seen it done - although the bags didn't pop the leveling units reversed themselves. Even a main dealer said it was ok to lift a L322 by that method.
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
This blaming the garage is confusing me.
