Home > Maintenance & Mods (L322) > Headlight bulb help!!
jfb1977
England 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
So, I've upgraded my fogs and sidelights to LEDs, which are much brighter, but they're also both about 6000k in colour rather than the OEM 4300k.
As such I want to upgrade the main beam and dipped beam bulbs to match at 6000k.
My car is a MY2007 Supercharged SE with the adaptive bi-xenons.
I'm happy that I just need H7 55w halogens for the dipped beam, but can anyone tell me for certain what I need for the main (xenon) beam? I THINK it's either a D1R or a D1S - what's the difference? Both look like they'd fit...
It's chucking it down and I don't have a garage, so can't go and pull them out right now to check.
And finally - are the static bending (cornering) bulbs H8s?
I've looked for all this info in the owners manual and it's worse than useless... Past (too many to list, but a few favs)...
2007 Porsche 997 C2S Coupe
2007 FFRR 4.2 S/C
2012 Jag XKR 5.0 S/C
2014 Merc SL500 AMG 4.7 V8 BiTurbo (remapped to 560BHP)
2011 FFRR 4.4 TDV8 Vogue SE - Overfinch Conversion
2012 Porsche Cayenne Turbo
2018 AMG C63S Estate
2015 Mercedes GLE63S
2017 Maserati Levante Diesel
2017 Audi A6 Avant 3.0 Black Edition
Post #121051 9th May 2012 7:21pm
daveo
hi, you will need d1s bulb for you head light. V8 facelift Range Rover Autobiography 22" wheels.
Post #121052 9th May 2012 7:44pm
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
I'm not 100% certain but if you have bi-xenons it should be 1 xenon bulb for dipped and main beam with a shutter mechanism, plus a fill-in halogen main beam which comes on in addition to the xenon bulb.
Sorry this doesn't give you a total answer, but it may stop you buying unnecessary bulbs Very Happy
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #121053 9th May 2012 7:45pm
jfb1977
daveo wrote:
hi, you will need ds1 bulb for you head light.
Thanks Daveo. I assume you mean D1S right?
And thanks Dave699, as I mentioned, I do have the adaptive bi-xenons and I know one is halogen and one is a 'proper' xenon bulb.
So I'll need D1S for the main beam, H7s for the dipped beam. Cool.
Now I just need confirmation on the cornering lights and I'm ready to order!
Anyone know the bulb size for the static bending lamps? Question Idea Question Past (too many to list, but a few favs)...
2007 FFRR 4.2 S/C
Post #121055 9th May 2012 7:56pm
DMRR
Other way round, dipped is Xenon, main is H7.... Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #121057 9th May 2012 8:03pm
jfb1977
You're right.
That terminology always confuses me...to me "main" sounds like your normal (main!) headlights and "dipped" sounds like side lights. But dipped are your 'normal' headlights that you use all the time and main are...to use a technical term...your 'flashers' (full beam).
Very confusing. Past (too many to list, but a few favs)...
2007 FFRR 4.2 S/C
Post #121058 9th May 2012 8:09pm
daveo
this is the one,
1/4 of a twist anti clock wise and its out
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  V8 facelift Range Rover Autobiography 22" wheels.
Post #121059 9th May 2012 8:10pm
daveo
and for the cornering lights
Post #121061 9th May 2012 8:16pm
jfb1977
Perfect, thanks Daveo.
Now I need to decide whether to buy proper error free SMD LEDs or try "xenon look" bulbs which are a fraction of the price....hmmmm.....
So...to swap out all the bulbs at the front of the car I'll need -
2 x D1S xenons for the dipped beam
2 x H7 for the main beam
2 x 501 for side lights
2 x H8 for cornering lights
2 x H11 for fog lights
Thumbs Up Past (too many to list, but a few favs)...
2007 FFRR 4.2 S/C
Post #121062 9th May 2012 8:30pm
jfb1977
Once again fullfatrr.com saves the day!! Bow down Bow down Past (too many to list, but a few favs)...
2007 FFRR 4.2 S/C
Post #121065 9th May 2012 8:38pm
if it was mine , i would go for ,
2 x D1S xenons for the dipped beam ----------- go for 6000k temperature bulbs, more of a whiter light..
2 x H7 for the main beam --------- xenon look bulbs
2 x 501 for side lights --------- smd bulbs
2 x H8 for cornering lights ------- ?
2 x H11 for fog lights -------- again, xenon look bulbs ... - .- -.
Post #121124 10th May 2012 11:01am
jfb1977
I think you might be right. I was considering SMD LEDs for the H7s and H8s, but a) they're expensive and b) I don't actually know how well LEDs will perform for full beam and cornering and actually given that they're not on all the time it's less important.
I've got cree LED fogs in though...they look great! Will get all of this gubbins fitted and take some pics... Thumbs Up Past (too many to list, but a few favs)...
2007 FFRR 4.2 S/C
Post #121133 10th May 2012 11:12am
as my td6 has bi-xenons ,i put smds in my main beam and it looked pants and as you say they arnt used much..
just a thought why dont you wire up the fogs as drl's...me and tim [joe90] have done so and they do look good. ... - .- -.
Post #121135 10th May 2012 11:17am
jfb1977
Hmmm. I'd be a little worried about doing that as the Cree LEDs are so bright I might dazzle people - they'll be great cutting through a pea souper but might be a bit much for DRLs. Past (too many to list, but a few favs)...
2007 FFRR 4.2 S/C
Post #121155 10th May 2012 12:35pm
your choice, but the amount of very bright drls on the road at the moment i dont think you'd have a problem... ... - .- -.
Post #121168 10th May 2012 1:36pm
