Home > Duckworth Parts > Replacement Rear View Camera
supershuttle
Rear camera
Quote:
I've done a search. but can't find anything on this:
What's the difference between the 2010 camera and the older ones? Can it be retrofitted to cars which already have an older camera (2007-2009)?
Me to please Very Happy Geoff
Post #138841 31st Aug 2012 8:25pm
daveo
there are a few types, the first cameras were cmos and low res, these were prone to leaking the next version were CCD and gave a far better picture added with the higher res of the touch screen, now on the 2010> they started to use HD or high res cameras if it had the surround camera system fitted but these will not fit onto the earlier system
new style camera 4 pin connector
now the early camera has a 2 pin connector for the power and ground and a coaxel for the signal
you can still find the early style fitted to the late cars but i cant comment if they are any better as i have not tried one but they will work on the early cars
just a point to think about, if you have a pre touch screen it will be low res so dont go spending big money on a after market hi res camera as you will not see the benifit.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  V8 facelift Range Rover Autobiography 22" wheels.
Post #138848 31st Aug 2012 8:54pm
tomthevet
Scotland 2005 Range Rover Vogue Td6 Tonga Green
Dan?????
Do you still do the updated camera, loom and mounting plate to go to a 2 pin and separate coaxial type cable?
This is for a touchscreen 2006 car with a knackered camera.
Also do you do the seat side panels for an aspen drivers seat?
T
I will PM this as well just so you get it.
Post #169782 3rd Feb 2013 7:33pm
Fozzauk
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Santorini Black
I am also interested if you still do the updated camera for a 2006 touchscreen?
Post #174441 25th Feb 2013 1:27pm
jean-claude
Belgium 2007 Range Rover Vogue TDV8 Tonga Green
Hello,
[quote="daveo"]...just a point to think about, if you have a pre touch screen it will be low res...[/quote]
Please, 2007 MY TDV8 is "pre touch screen" ?
Thanks,
jean-claude
Post #174460 25th Feb 2013 3:18pm
your screen is a 'touch screen' made by denso.. ... - .- -.
Post #174464 25th Feb 2013 3:27pm
jean-claude
Thank you Stan,
but is low-res or not ? So, I may get benefit to change my rear camera for a newer hi-res ?
I know is not a 2012 but I don't know if a difference exist between ea : 2005 and 2007
jean-claude
Post #174487 25th Feb 2013 4:18pm
changing the reverse camera to a hi-res one will help .... ... - .- -.
Post #174489 25th Feb 2013 4:24pm
jean-claude
Thank you.
Here is I know of the my screen : "The TSD is a touch sensitive, 800 X 480 pixels liquid crystal display (LCD) VGA screen which displays in a 15:9 format." so, the picture may be better but before get a new camera I'll do a test with some camera that I have (webcam etc etc)
jean-claude
Post #174532 25th Feb 2013 7:22pm
ianmacd
United Kingdom 2010 Range Rover Vogue TDV8 Epsom Green
I too am after a replacement rear camera for a 2008 model. Can you source the updated 2010 non-vision assist camera and will this fit in place of the current one?
Thanks.
Ian. Current: RR L322 2010
Past: RR L405 2017, RR L322 2012, 2008 & 2004, 2018 D5, 2016 Defender, 2011 D4, a few Disco2s, P38, RR Classic, couple of Disco1's, SIII SWB
Post #205215 22nd Aug 2013 9:47am
