Home > Technical (L322) > The Jag engine was only ever fitted to the RRS |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7805 |
Indeed, my Range Rover 40th Anniversary book states that the 4.2 is a sleeved version of the 4.4, and the valve timing is also fixed ie set and doesn't vary, on the Supercharged.....
1st May 2012 10:53am |
cast iron wet liners and fixed rate valve timing ,my engine is straight out of the 70's 2008 MY Supercharged
2nd May 2012 9:21am |
