Home > In Car Electronics (L322) > sound problems
cleughy
England 2004 Range Rover Vogue Td6 Santorini Black
sound problems
i lost all my sound in my 2004 (non touch screen).
it was diagnosed as the amp LR006197, this worked for a few hours after getting a recon until from the dealers.
then sound partially went again (apart from sat nav) then altogether, now i am being told that its the analogue tv module YIL 000023 that needs replacing.
does this make sense or am i dealing with somebody who does not know what they are doing?
i am loathe to go the main dealers as they want £120 +vat just to diagnose what the problem is.
if it is the tv module is there a cheap place to get them, specially with analogue not being there anymore.
cheers
steve
Post #119411 28th Apr 2012 7:37am
You can check to see if the tv module is at fault by removing it and connecting the sat nav directly to the two plug connectors that previously connected to the tv module.
You need to remove the sat nav from its mounting frame and lay it in a position you can get to the two plugs.
Post #119413 28th Apr 2012 7:58am
mjdronfield
Just to make things slightly more confusing (!!), the dealers tend to call the DSP unit the amp, but its not, its a sound processor. The actual power amplifier section of the system is in the BM54 radio module, of all places.
I had mine upgraded for better amps and clearer sound ;
http://www.fullfatrr.com/forum/topic10342....54+upgrade
but it also fixes any amp problems, which are quite common I believe.
Baris, who does the work, joined this forum to help us with the upgrades.
I'm sure if you get in touch with him, he may be able to help you diagnose the issue, one way or another..
Mark
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #119427 28th Apr 2012 10:29am
cleughy
on further investigation the power pin on the amp has broken off, its now in an electrical repair shop where they are attempting to graft a wire on to replace the pin as they say you cant get a replacement unit to fit.
we'll see if this solves the problem next week.....
Post #119433 28th Apr 2012 11:02am
Baris
If they fail, I have plenty of spare parts to fix it properly. I can just replace the whole pin for you.
Post #122776 20th May 2012 5:36pm
