![]() | Home > Photos, Videos & Media > funny vid on youtube of rr earning its keep |
ogy Member Since: 24 Sep 2010 Location: Yorkshire Posts: 50 ![]() ![]() ![]() |
put yuppie contracting in youtube. who needs a tractor. |
There's one to avoid buying then. Would have been better to use a D3 or a Snort, at least they have a chassis. Body damage on FFRRs which have towed excessively heavy weights are well documented.
Thought I would stick the link to it
Never mind the body damage, the airbags at the rear will be feckered as they will have run upto max pressure(so stressed the compressor as well) and they still couldnt get it up to level as the tow ring on the trailer is too low. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Over load the back end of a Range Rover and you will fook the compressor |
I once moved the STBX Fathers farm trailer which was about 2 tonne on a single axle using its nato/farm hitch a few hundred yards from one side of the land to the other and just used low range and didn't move it to full hieght but it coped OK for that distance but wouldn't do it again and i had just washed the car and the bags(the dirt and grit in them is a big killer IIRC) but can imagine that the car was really feckered after the above video and suffered some warranty work for the rear end bush's and suspension arrangement |
