Home > Technical (L322) > Problem locking with key fob
hoppy
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
would be most grateful if anyone could offer some help.....
just disconnected the battery to change my steering wheel....all good
until i reconnected battery..everything works ok..bu now can not lock the car with my key fob..light flashes on the fob
plus the battery was changed on the fob last month..so not that..
any ideas anyone....cheers...
Post #118173 18th Apr 2012 5:07pm
Walk away and try later
Use key in lock (yes, novel Wink) and start car as normal, fob should synchronise?) (Alarm might go off until you put key in ignition?)
Disconnect the battery again, leave for at least ten minutes .
Post #118179 18th Apr 2012 5:48pm
hoppy
Cheers joe....will give it a go..
Post #118184 18th Apr 2012 6:07pm
hoppy
Re: Problem locking with key fob
No joy....yet it unlocks the tailgate..... Censored ....trip to the stealers is in order now....gonna turn a relatively cheap steering wheel into an expensive one... Big Cry
Post #118185 18th Apr 2012 6:24pm
hoppy
even tried this method of another forum.....
Reset Procedure for your key fobs
Every signal from the remote handset contains the transmitter identification code and a rolling code. The BCU checks
the codes and only responds if the signal is from a valid transmitter. During vehicle production, the remote handsets
supplied with the vehicle are initialised to set their individual transmitter identification codes and synchronise their
respective rolling codes with the BCU. If a transmitter loses synchronisation with the BCU, or if a replacement or
additional remote handset is to be used with the vehicle, the initialisation procedure must be repeated. During the
procedure, all remote handsets for use with the vehicle must be initialised.
Initialisation Procedure
1 Ensure the vehicle is unlocked and the driver and front passenger doors are closed.
2 Install a key/remote handset in the ignition switch, then turn the ignition switch to position I and back to position
0 in less than 5 seconds to put the BCU into the initialisation mode. Continue the procedure within 30 seconds
of turning the ignition switch to position 0.
3 Remove the key/remote handset from the ignition switch.
4 Press and hold the unlock button for a maximum of 15 seconds. During this time, momentarily press the lock
button three times within 10 seconds.
5 Release both buttons.
6 Successful initialisation is indicated by the BCU locking then unlocking the vehicle. If this does not occur, repeat
step 4.
7 Repeat steps 4 and 5 with all other remote handsets belonging to the vehicle (4 maximum). Begin the
initialisation of each remote handset within 30 seconds of completing the previous initialisation, or the BCU will
drop out of the initialisation mode and the complete procedure will have to be started again
Still no joy.... Big Cry
Post #118187 18th Apr 2012 6:30pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
Took me a good few tries to get the sequence above to work.. If it fails, sounds like u might need a new key..I got a furnished one from a place that repair car keys only. €80.
Post #118189 18th Apr 2012 6:47pm
hoppy
must have tried about 10 times already..... might just go the pub instead.... Razz
Post #118193 18th Apr 2012 6:54pm
Lolo
Will probably work tomo Thumbs Up
Post #118194 18th Apr 2012 6:54pm
hoppy
i wont after a head full of guiness.....mmmm Thumbs Up
Post #118199 18th Apr 2012 7:13pm
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Try holding the key near to the top of the OS door pillar whilst doing the procedure as that's where the rempote reciever is. 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #118219 19th Apr 2012 5:19am
hoppy
tried that...tried everywere....think the only place i haven't tried is where the sun don't shine... Neutral Shocked
Post #118220 19th Apr 2012 5:56am
if you do try that , take some pics ...could be a laugh... Laughing ... - .- -.
Post #118224 19th Apr 2012 7:02am
hoppy
lol... after careful study of fob dimensions.... i have realised it wont fit... Very Happy
Stanley old boy....you need to get out more..... Shocked Thumbs Up
Post #118225 19th Apr 2012 7:06am
hoppy
must have tried this 20 odd times..no joy, booked it in to main dealers this morning (£40)..after half an hour they come back and tell me
even they cant do it,,,tell me they need the car for 3 days to find fault...as much as i would like it fixed
there's no way im payin the dealers 3 days labour... Big Cry
any ideas would be most welcome.... Thumbs Up
Post #119123 26th Apr 2012 9:05am
DMRR
Do the interior lights work? If not ... check the BCM fuse. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #119133 26th Apr 2012 9:49am
