Home > Maintenance & Mods (L322) > High Stop split
ahebron
New Zealand
High Stop split
Who else has had the high stop brake light split on its leading edge?
On my 2003 TD6 it has split right across and started to buckle upwards. Can it be repaired I ask hopefully or is it a replacement part?
Adrian VW Amarok 2014 Highline auto
Post #118054 18th Apr 2012 7:25am
Not split yet, but it is starting to buckle upwards .
Post #118064 18th Apr 2012 8:03am
A dab of superglue along the split edge and held in a vice or clamp will sort it Thumbs Up
Post #118066 18th Apr 2012 8:11am
Mr Tee
New unit, replaced mine last week, dead easy, cover off inside top of tailgate, release 3 bolts, disconnect electrical connector, remove spoiler, unscrew light fitting, replace. Hardest part is getting the rubber grommet into the top of the tailgete.
Post #118067 18th Apr 2012 8:14am
ahebron
New Zealand
Mr Tee, how much and who from?
This is obviously a common-ish fault. Interesting that all replies so far have been owners of early L322 TD6.
Post #118068 18th Apr 2012 8:16am
No surprise it's the early ones - weather fatigue probably.... .
Post #118069 18th Apr 2012 8:24am
Mr Tee
Adrian
Bought from my good mate Dan @ Duckworths Bow down Been buying that much stuff from him that I think he's going to set me up with an account soon!! As for price, think it was around £40 + VAT or thereabouts. Mine had some failed LEDs and when you see then side by side the old one looked very battle scarred, a nice easy fix though!
Post #118071 18th Apr 2012 8:41am
stuboy00
Scotland 2006 Range Rover Vogue SE Td6 Java Black
Not true joe mine is a 55 plate VSE and it's split and got some LED's out probably with water ingress
Post #118084 18th Apr 2012 9:21am
Mine looked like it had been in WWII, so I decided to smarten it up
Before
Half way through
Finished product
Post #118100 18th Apr 2012 10:36am
Mr Tee
Do you use cutting compound for that result?
Post #118121 18th Apr 2012 11:44am
Think he used his wife's tongue , you won't find anything more cutting than that …. Laughing Laughing Wink
Post #118123 18th Apr 2012 11:54am
Mr Tee
Rolling with laughter Rolling with laughter
Post #118131 18th Apr 2012 12:20pm
The wife's tongue is so rough it would have shredded the light Whistle
Yes start with a course cutting compound then fine compound and finish with a very fine polish something like Autoglym resin polish or Mer
Post #118134 18th Apr 2012 12:24pm
