Home > Technical (L322) > Vibration!!!!!
try some injector cleaner and then good blow out first.. ... - .- -.
Post #119800 1st May 2012 3:01pm
Mr Tee
ARH Vehicle Logistics wrote:
I had thoughts allong the lines of injector!!!! what do i do to source the offender??
Need to perform a leakback test, search for faulty injector.
Post #119801 1st May 2012 3:03pm
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
I too had this problem, it was the injectors..
Take it to Land Rover, they'll plug in a laptop and tell you what's wrong - but get the work done somewhere else to save money!
I had exactly the same symptoms as you, have a read here: http://www.fullfatrr.com/forum/topic6961-75.html
Previous owner had fitted the wrong injectors Laughing
Post #119803 1st May 2012 3:21pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
When I had my vibration it did turn out to be the TC, but before they changed it they had already changed all six injectors.
They also changed the active engine mounts, maybe get them checked.
Post #119804 1st May 2012 3:45pm
daveo
told you, not that i wanted to be right but it seems to be a very,very common fault and you will find now that most of the warranty companys reject the repair.. V8 facelift Range Rover Autobiography 22" wheels.
Post #119818 1st May 2012 5:49pm
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
??? told me? lol If i could would you!!!!
Post #119868 1st May 2012 9:15pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
My TR6 was showing possible symptoms of gearbox failure, but it turned out to be a seized rear brake calliper No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #119885 1st May 2012 10:41pm
