Home > Technical (L322) > Lambda readings at idle ( including graphs ! ooohhh ;-) ) |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 |
Fisha,
29th Mar 2012 8:46pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1371 |
I went with a bearmach one... Figured it would be better than a britpart one. Maybe not eh?
29th Mar 2012 10:20pm |
Can check that on Saturday if it helps 5.0 supercharged autobiography
29th Mar 2012 10:30pm |
Jonno, if you could that would be great.
29th Mar 2012 10:38pm |
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 |
This is information from my 2000 4.6L RR.
30th Mar 2012 2:37am |
algt2 Member Since: 01 Jan 2011 Location: Edinburgh Posts: 65 |
I had similar symptoms to yours and the fault showed up as a MAF sensor a previous garage had changed all 4 of my lambda sensors because of emissions readings but I still had the issue. I then saw Andy White at whites auto services in edinburgh and had the MAF changed and the fault was still there, the guys at whites then stripped out the throttle body and hoses and cleaned the internals and linkages, they said that there was a bit of gumming on the flap inside, since this was cleaned I've not had any problems. |
30th Mar 2012 7:01am |
125% throttle is kick down I think.
V8 or else ... |
30th Mar 2012 7:11am |
While you're under the hood staring at the engine, trying to make your wife think you know what you're doing...
30th Mar 2012 4:52pm |
Just checked with Autologic and my idle runs at about 25kg/hr.
31st Mar 2012 1:41pm |
I've tried spraying the whole area with wd40 .... No changes. Tried opening the oil filler and dipstick... No change.
31st Mar 2012 8:03pm |
Okay doky ...
2nd Apr 2012 7:55pm |
Fingers crossed, had mine cleaned up about a month ago and touch wood it's been great, before that I got reduced performance warnings about three or four times a day along with rough idle and stalling! |
2nd Apr 2012 8:51pm |
I even think visibly there was a differenc ebefore and after the cleaning. The flap looks like it closes further and tighter now.
2nd Apr 2012 9:25pm |
bad news ... its still reporting running rich. its doing my head in.
5th Apr 2012 9:05am |
