Home > Technical (L322) > Tickover Query
dan_uk_1984
Does it whether it's on petrol or LPG, but as above only seems to do it when it's raining, or at least that's when I notice it. It's been dry for a few weeks and I'd forgotten about it.
The idle speed is increased by the ATC ECU if it detects a voltage drop, so next time it's doing it (seems to be ok at the moment!) I'll see what the voltage reading is. As it happens when it's wet it could be an alternator fault cropping up.
D
Post #15175 19th Mar 2010 10:04pm
Jem0911
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
To me being a simpleton it sounds like the auto choke?
Mine does the same on start up then settles. 15MY SDV8 Vogue SE
Post #15176 19th Mar 2010 10:06pm
dan_uk_1984
I also thought it could be the "cold start" over fueling, but I ruled this out due to the fact it does it on LPG as well and the petrol ECU & injectors is bypassed when on LPG.
I have high revs 1100 for about 30 secs on startup, i believe this is normal behavior when cold.
Post #15178 19th Mar 2010 10:10pm
Petru
Russia 2007 Range Rover Supercharged 4.2 SC V8 Baltic Blue
Hi, guys. Any thoughts?
Got 900rpm after carwash at -18* Celsius. Russia, you know.
But noticed, usually have around 1000 at the cold start for a while. Than 600-700.
Post #365362 5th Jan 2016 11:23am
