Home > Maintenance & Mods (L322) > 52 RR Vogue TD6 hesitating when accelerating |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
I'm no expert, but my first thought is fuel pump, or injectors. Does it happen only under hard acceleration?
29th Feb 2012 1:12pm |
jimwise68 Member Since: 29 Feb 2012 Location: Chelmsford Posts: 12 |
Yes it's only under hard acceleration. Fuel level is irrelevant.
29th Feb 2012 1:15pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
When did you last change your fuel filter? |
29th Feb 2012 1:28pm |
Errr bought the car last August, it came with FLRSH so presume its been changed when it should.
29th Feb 2012 1:41pm |
Presume nothing, especially where main dealers are concerned. |
29th Feb 2012 1:51pm |
Where us best place to get fuel filter? Is it a standard inline or a specific RR item? |
29th Feb 2012 2:20pm |
29th Feb 2012 3:04pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 |
Had similar issues..
29th Feb 2012 10:03pm |
Thanx RRUK. Just read your post. It's exactly same as nine. 3,000 rpm and the stuttering starts.
29th Feb 2012 11:21pm |
The fuel pump in question is external to the fuel tank on the chassis, therefore easier to swap out. There's an in line fuel filter I think but also a fuel sediment filter trap under the bonnet which is a £10 part you can swap yourself as I did when I gave the TD6 a service.
1st Mar 2012 9:22am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2656 |
Had the exact same issue in the last month, low pressure fuel pump as previously mentioned. |
1st Mar 2012 12:11pm |
Thanks for the info. Im ordering one once i get the part number from the local Stealer. |
1st Mar 2012 12:13pm |
Get in touch with Dan 01673 844 722 |
1st Mar 2012 3:09pm |
Situation update: changed the fuel filter abd problem solved.
3rd Mar 2012 4:07pm |
