Home > Maintenance & Mods (L322) > Options
Page 3 of 4 <1234>
Flashman
Now that sounds good. Tom
Current Drive
Previous Drives
Post #114878 26th Mar 2012 3:31pm
SteveMFr
Site Sponsor
salb wrote:
So now we are sayin the iid tool will fold the mirrors
Sal
No. Sorry if that came out wrong.
With the IIDTool we can change options in the CCF.: FBH fitted, Power fold mirrors fitted, allow TV in motion, turn on main beams as DRL, etc, etc etc. But these are all items that LR already programmed into the various ECUs. The IIDTool allows you to "reach in" and switch these options on or off or alter them.
For the mirrors to fold, you need an ECU to send the mirrors a 'Fold Now' message when the car is shut down. LR (BMW) never programmed this option on the pre 2010 L322. So you need an extra-module of some sort that listens for the 'Car is shutting down' signal and broadcasts a 'Fold Now' message. Or the elegant but very costly way to achieve this is to write a bit of code that does this and flash it to an ECUs memory (the cheapo way would be to use a relay/timing circuit that bridges the contacts on the fold switch momentarily on start and shut down).
But I had assumed that, since the mirrors were changed on the later models, the message had changed as well. Seems it hasn't. So a mirror fold module will theoretically work on all L322s 2002-09.
That's what I meant.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #114901 26th Mar 2012 5:30pm
5IMON
Re: Options
oodathort wrote:
I made a little circuit that closes my mirrors on lock and opens them on unlock it also switches my side lights on for DRL any other things that people want without dealer programing ??
Sidelight activation upon unlocking of vehicle. When I mean side lights what I mean is Sidelights (Front and Rear) , Puddle lights and numberplate lights 20-30 second delay.
- Also to dimmer on and dimmer off.
And
Upon locking vehicle vehicle lowers ride height to entry level and side light activation (same as above).
And
upon locking and unlocking, the vehicle beeps ?
Very Happy
5I
Post #115045 27th Mar 2012 3:52pm
Re: Options
not a good idea..vehicle must be moving when activating access mode, its in the manual.. ... - .- -.
Post #115076 27th Mar 2012 6:55pm
5IMON
Really? So access height cannot be acheived at standstill?
Im sure on the 06-09 RR's access height can be acheived with vehicle unlocked and no key in the ignition?
I witnessed cam-tech-craig's range rover being lowered yesterday and that was at a standstill. On reflection though he did have the key in the ignition and an IIDTool installed...
Post #115085 27th Mar 2012 7:19pm
yes it can be done at standstill, but the manual recommends that the range is moving when doing so... ... - .- -.
Post #115086 27th Mar 2012 7:23pm
Simon hi, key was in ignition but IID was not connected. To lower the suspension the ignition needs to be on only (engine need not be running) but to raise the engine needs to be running... Hope that helps...
Craig Thumbs Up
Post #115132 27th Mar 2012 10:54pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
I use the height access a lot, and mine works with key out but i only get a certain amount of time once key has been removed, like 30 seconds or something Thumbs Up
Post #115137 27th Mar 2012 11:29pm
As long as you have not opened the doors Lolo then yes it gives you a min or two but as soon as you open the door then you need to turn the ignition back on to lower it...
Craig Thumbs Up
Post #115140 27th Mar 2012 11:40pm
5IMON
Now that we know the parameters and constraints of accessing ride with the key removed from the ignition, odoothort could you create a program to cater to this?
Also
Is it possible to slow the (what will be the) side light illumination process to that of the default settings to create a slower wake up?
For example ;
Correct me if im wrong but currently it take 2-3 seconds from pressing the unlock button for the puddle lights and interior lights to illuminate (from 0 watts to 4 watts). Could this illumination process be slowed down almost staggered to 6 or 10 seconds from start to finish.
This would really cool if its possible. It would create the affect of the car waking up. Mr. Green
Post #115142 28th Mar 2012 1:37am
SteveMFr
Site Sponsor
One of the items to consider when attempting large suspension movements in the L322 (or any modern LR) at rest is that, in contrast to the solid axle vehicles, the suspension moves the wheels through an arc as it goes up and down moving the wheels in and out relative to the body and each other. If the vehicle is moving, the tires can 'scrub' outwards or inwards depending on whether the suspension is going up or down.
This effect can be so extreme that when lowering to access form standard height, the vehicle can actually 'hang' on its binding suspension. This could potentially lead to a dangerous situation if one or more of the tires are close to the limit of adhesion (some gravel, for instance) and the vehicle suddenly drops the rest of the way. I assume that it is for a reason such as this that LR recommends that the vehicle be moving.
This thread is moving a bit away from the original topic, tho. Sorry for that ood.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #115152 28th Mar 2012 7:51am
salb
United Kingdom 2007 Range Rover Vogue SE Supercharged Santorini Black
Original thread was posted Nov 2010,
Is this forum member still an active member
Sal RANGE ROVER OVERFINCHED 4.2 S/C
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
STAINLESS STEEL EXHAUST O/F
CARBON FIBRE WING MIRRORS & A PILLARS & CENTRE CONSOLE
Post #115154 28th Mar 2012 8:06am
Lolo
Not sure what u mean? The thread was started feb 2012, by a member who joined in nov 2010.. Thumbs Up
Post #115164 28th Mar 2012 8:45am
Steve, whats a "tire"? please use the Queens English... Its a "tyre" here where we all speak proper!!! Rolling with laughter Rolling with laughter Rolling with laughter
Sorry my friend i couldn't resist...
Craig Laughing Laughing Laughing
Post #115168 28th Mar 2012 9:09am
SteveMFr
Site Sponsor
Had this before. Geoff reprimanded me for speaking of a 'fall update'. Smile
Tire is close at least. But there are numerous instances where the picture in your mind would be something completely different than I intended such as 'open the hood and check the oil' or, non-car, '4hrs into an 8hr drive with my screaming kids I started to get extremely p-i-s-s-ed'... Laughing
(needed the hyphens to get around the censor)
Wow, now we are OT.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #115183 28th Mar 2012 9:59am
Page 3 of 4 <1234>
