![]() | Home > General (L405) > Less camouflage, More Rangie |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 ![]() ![]() ![]() |
the wrap is rotten |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1448 ![]() ![]() |
I'll see if I can find a pic of an old alloy beside the mules and compare. V8 or else ... |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
they are 22's i reckon:
In the past I would have agreed, however, the evoque is now sold with 20" alloys and a /45 ratio tyre ... apply that to the bigger RR and the above pics could indicate 22" with a lower /45 profile . It may not be as bad as first thought if the car can run variable damping which could potentially counter the lower profile harshness. V8 or else ... |
Could you try this with an (smaller) EVOQUE patern and this may end up appearing as being a 20 inch Evoque wheel with Evoque/FL2 patern. |
RRV Member Since: 05 Oct 2009 Location: Midlands Posts: 648 ![]() ![]() ![]() |
I have been told today 100% that the new FF has 22" rims as standard plus many many RRE bits. From the waist up its identical to the one we know & love. If you have nothing nice to say,say nothing at all. |
Its not as good as the first, and considering there is only 6mm difference in the PCD between the L322 and the Evoque/Freelander - its never going to be conclusive ... but it does look a smaller PCD on the evoque:
kkqd0298 Member Since: 02 Mar 2010 Location: London/Aberdeen Posts: 199 ![]() ![]() ![]() |
With 22's the brakes are starting to look rather weedy.
thanks for the info lads!
SAppie Member Since: 08 Feb 2010 Location: Berkshire Posts: 159 ![]() ![]() |
A few more....
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
Looks too much like a Sport to me. No longer FF owner but still interested. Present car Jaguar XE
I see the rear lights also have the winglet at the top too, not sure about that personally. Rr has always had a squarish rear light V8 or else ... |
2nd Rower Member Since: 24 Sep 2009 Location: Upside Down Posts: 62 ![]() ![]() ![]() |
Could be a trick of the photograph/camoflague, but looks like the tailgate split is below the number plate... thus the fold down piece is very small - like an X5!? |
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 279 ![]() ![]() |
I noticed the tailgate split too. Much better for loading, and you still have the flap to sit on (now beneath a slightly bigger umbrella |
