Home > Technical (L322) > L322 HDC Inactive warning on start up |
RANGEROVER Member Since: 25 May 2010 Location: EAST OF ENGLAND Posts: 48 |
Low battery because it's been stood a couple of days is the No.1 reason for it appearing then clearing itself. I would start being prepared to buy a Battery as the winter will soon show if it's getting past it's best.
5th Sep 2011 10:33pm |
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 |
it 100% doesnt stay on and the turns over quite swiftly.
5th Sep 2011 10:38pm |
DaveAngel Member Since: 15 Aug 2011 Location: Cowplain, UK Posts: 205 |
I get this too, and from this forum assumed it was battery.
6th Sep 2011 5:24pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
i got a bosch 020 from europarts..110amphr and 920 cca [crank] |
6th Sep 2011 5:45pm |
As usual, many thanks Scarey, will look into it __________________
6th Sep 2011 9:19pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Is that powerful enough for TDV8 or would I need something a bit stronger. Cant seem to get that Battery in Ireland. Only place found could supply me with a VARTA same spec but at 200 Euro + Vat @ 21% I declined. Present :2008 TDV8 HSE Gone Audi A5 2.7TDI Gone Discovery 3 HSE Gone Mercedes CLK Gone Range Rover 2.5 DSE |
6th Sep 2011 9:35pm |
any thoughts on this battery. how important is the Ah capacity. the bosch ones available on europarts or either 90 or 95 im sure.
6th Sep 2011 9:38pm |
that one from tanya will be ok.. |
6th Sep 2011 9:40pm |
I bought the genuine LR battery for my TDV8 and it cost me 141 quid |
7th Sep 2011 6:12am |
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 |
I get the HDC Inactive mesage appear usually in the mornings but then clears straight away, i have read on the forums that this is casued by low battey. I changed my battery a couple of months ago ( at main dealers) and was ok but have noticed the message coming back again. I had the dealer check the voltage of the battery and they said everything was ok. Howevevr i had to call the AA out to start the car before new battery was fitted and he said that there was something definatly drawing power.
5th Dec 2011 10:56am |
check the obd port flap is closed..the battery needs to be a 110amp 920 cca type like the varta/bosch 020..did they turn the steering wheel fully left lock and then fully right lock. this sets the steering parameters .. |
5th Dec 2011 11:20am |
The battery was supplied and fitted by Strastones in cardiff, i would assume that they did what was required?? ................... but then again perhaps not, the times i have taken back tools found under the bonnet, or the time they chnaged the fuel pump and left a pipe of, i wondered why people where flashing me as the car was smoking, by the time i got home, lost a lot off fuel, all over the engine and burning, or the time they chnaged the fuel pump again and reversed some wires so when in the fast lane of motorway car cuts out, tank said half full but was really on empty!!!!!!! I realy should have let my solicitor sort that out as i had the children in the car!!!!!! |
5th Dec 2011 12:01pm |
Definitely an indication of "Low Voltage" at start-up. Only fix is a new battery. |
5th Dec 2011 12:04pm |
Like i say Land Rover Dealer fitted a new battery this year so if it has low voltage already then something is definatly drawing power but i dont know where to start. Dealer says that all is ok, AA say that something is using power, you would expect the dealer to know most of the issues??? |
5th Dec 2011 11:18pm |
