Home > Maintenance & Mods (L322) > Touch-up kit?
AMV
2011 Range Rover Vogue TDV8 Santorini Black
Touch-up kit?
Sirs,
has anybody of you tried the OEM touch-up kit? Any suggestions on how to use it better?
Bought a couple of kits and will try them soon Very Happy
 Santorini Black RR Vogue 4.4 TDV8
Post #78566 31st Aug 2011 9:28pm
Googsy
I bought this too for mine. Its suggested on a lot of the detailing sites thats its best to mix the paint and the laquer in a mix of about 4 parts to 1 this is better than applying paint first and laquer afterwards as it improves your chances of a better finish.Its the laquer that gives your paint the shiney finsh. I did this however and found the laquer in the kit became very gooey and started to dry quickly making it difficult and lumpy to apply. I Had some halfords laquer I mixed instead with the paint and allowed me more time to use and touch up. The brush that comes with it is useless you are better applying it with a fine art brush as this gives more control . The secret is to apply as little as possible and build up in layers . I normally mix paint on laquer on a piece of old cardboard and use this as a palette. For a sctrach its best to apply using a cocktail stick. Hope that helps. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #78571 31st Aug 2011 9:39pm
AMV
Thanks for the input, googsy2 Bow down . It seems to me it's like an art and you must have some talent to succeed Very Happy
Are you happy with the result? Have you polished the scratch after detailing? Santorini Black RR Vogue 4.4 TDV8
Post #78575 31st Aug 2011 10:02pm
Googsy
Lets say its work in progress I only know this information as I made a total Censored the first time Thumbs Up
Less is more with the touchup build it up in layers if filling a stone chip. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #78580 31st Aug 2011 10:24pm
If you need touch up paint these people produce 100ml cans to order for about £10. The paint comes with pre-mixed laquer if you don't order laquer separately, even supplied with a paintbrush. The paint is good quality and is far easier to apply than "touch-up kits". I've used a number of tins on previous cars with good results. Also supply aerosol cans if you want to colour code bits or repaint larger areas.
http://www.paints4u.com/productsByCat.aspx...42&p=1
Post #78597 1st Sep 2011 7:56am
+1 Thumbs Up [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #78634 1st Sep 2011 11:26am
M44K TS
On a detailing course, the bloke advised to go to Halfords and buy a couple of empty touch up bottles, (they should have them behind the counter) and put your touch up paint in there, they have a finer brush and also a small metal nib which is ideal for stone chips. The dealer ones, the brush is too big. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #78671 1st Sep 2011 2:03pm
