Home > Technical (L322) > New member 1st post - Rear toe issue L322 2011 |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
What do you mean by the subframe was displaced? As the suspension is mounted to the subframe, the subframe must be correctly located. |
29th Feb 2024 3:42am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3206 |
A 'displaced subframe' would certainly throw off wheel alignment as it's measured relative to the body . Impact damage or worn mounts could do this. 2012 TDV8 Vogue (L322) |
29th Feb 2024 8:29am |
Anglo77 Member Since: 28 Feb 2024 Location: New York Posts: 9 |
By displaced, I mean that I dropped it by a few inches to get access to the control arm link bolts. |
29th Feb 2024 12:07pm |
Wiltshire130 Member Since: 05 Aug 2023 Location: Wiltshire Posts: 22 |
29th Feb 2024 12:52pm |
Cheers Wiltshire, yep this along with the link rod were replaced. On the limits of the eccentric washers it won't come into alignment.
29th Feb 2024 4:02pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1206 |
I replaced mine with 'Lemforder' ones and the right wheel won't quite come into line.
1st Mar 2024 12:08am |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
I have the same the nearside rear is slightly out has been for about 25k miles and no adverse wear showing on tyres nor on handling |
5th Mar 2024 4:32pm |
If the total rear toe is within spec it will self centre with an automatic correction from the front axle albeit with the car body slightly off centre to the direction of travel. 2012 TDV8 Vogue (L322) |
5th Mar 2024 6:21pm |
Glad to report, found the problem and now it's all on the straight and narrow.
20th Mar 2024 8:34pm |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 419 |
I'm not 100% sure, as I've never had to touch toe on any of my L322's. It's always been camber adjustment following upper / lower hub knuckle changes.
20th Mar 2024 11:32pm |
No, as the eccentric washer is attached to the head of the bolt and the groves cut into the shank of the bolt align the one under the washer, they turn in unison. As they turn, they act against the raised nodules either side of the washers. This then alters the distance from the fixed point (the nodule on the subframe) and the centre line of the bolt. So, the bolt moves along the slot. One revolution then starts the travel back along the slot.
21st Mar 2024 12:18am |
OK, thanks, that makes sense. I stand corrected.
21st Mar 2024 2:45pm |
Cheer @D3Jon, me too it was doing my nut in. 2011 L322 5.0L HSE & 2018 Discovery Sport 2.0L
21st Mar 2024 8:06pm |
