![]() | Home > Maintenance & Mods (L322) > Checking engine oil level |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
I've noticed that when I initally pull dipstick to check oil level the level is below minimum, then when I re-insert and re-check it shows maximum |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35511 ![]() ![]() |
i thought its best to check the engine oil when its cold and settled in the sump.. |
That's how I would usually do it. ![]() When "first parading" a vehicle in the army, never been told to check when it's hot (Unless I've not been listening properly ![]() It would mean before I start a journey, starting vehicle, letting it warm up (10 minutes say) then shutting engine down, checking oil level 5 minutes later and possibly finding then that it's to low and may have damaged engine. Contradicting advice on the internet ![]() |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
Method is made quite clear in the owners handbook. Check with oil cold and car on a flat surface |
Steves997s Member Since: 02 Apr 2011 Location: Ascot Posts: 26 ![]() ![]() ![]() |
The handbook says check when cold. It then goes on to say that if you have to check after the engine has been running then leave the ignition switched off for 5 minutes to allow the oil to collect in the sump.
When oil is hot it expands and therefore will increase in volume when in the sump. If you have the oil at the top mark when cold it will be over when hot hence the reason you should check when hot.
Dogman Member Since: 10 Dec 2010 Location: UK Posts: 174 ![]() ![]() ![]() |
Have to check my 911 oil when it's warmed up fully but that's because it runs a dry sump.
Yes, you can check it when hot but it has to be properly hot which means a decent run first. If you think the level is too low then getting it hot first seems to have the potential to do engine damage. Leaving it to idle for a few minutes wouldn't get it hot enough, especially in the case of a diesel. There is a clear section in the owners handbook stating to check when COLD (their emphasis, not mine) and then states what to do depending on where the level is. If you read this you will see it takes into account the expansion of the oil. It does also say you can check when hot but this is quite clearly an 'only if necessary' message. I have some other cars, all of which are dry sump, and yes they have to be checked hot. But the tanks have a decent reserve (that is the point of it after all) so the level is less sensitive assuming you know there is a reasonable amount in there. |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
the level on the dipstick was designed with the fact the oil will expand taken into consideration hence the reason they say to check it when its cold...as if you fill it up to the level when its hot/warm then infact you will not be putting enough oil in the car |
