Home > Technical (L322) > Suspension questions
MichaelGG
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
Hi everyone.
My 2012 Westie is playing up compressor wise. It builds up pressure in the gallery to above 110psi then just exhausts it.
It turns off my height adjustment but no fault code or suspension inactive comes up.
It makes a really weird pulsing noise then dumps it again. I plugged the gap tool in but no faults.
The compressor slowly raises in temperature so I don't want it running for a while to check anything else.
Its in access mode at the moment and it doesn't drop either side.
Just wondering if anyone had any ideas.
This is the only thing that's weird to me on the tool.
I say no fault codes, but one did come up but for some reason hasn't come back up. This is the only one but hasn't come up for a while now.
Post #681246 27th Dec 2023 12:41pm
Paul H
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
I had similar when I had a hole in one of the airbags and it would leak.....but then it would drop you down to the bump stops.... have you tried recalibrating your ride heights to make sure it's not something there?
Otherwise put it in extended mode and listen for hisses 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #681269 27th Dec 2023 7:53pm
MichaelGG
Hi,
I'll try that thank you. I've noticed aswell it's not charging. I've found a belt that's half shredded for whatever reason, maybe it's that?? If the battery hasn't got enough charge does it shut certain things down?
Post #681285 28th Dec 2023 6:34am
