Home > Technical (L322) > Figure out if its been remapped? |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3203 |
Try timing 0-60 on a 'dyno' phone app. Some remaps increase the torque significantly (and the way it loads up) which is the main issue with the drivetrain rather than HP. 2012 TDV8 Vogue (L322) |
9th Aug 2023 7:33am |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 399 |
ah nutty 800nm of torque or someshit is what they pretty much said.
9th Aug 2023 7:52am |
Assume it is remapped and get it returned to stock if you are having gearbox issues and want to prolong it's life. 2012 TDV8 Vogue (L322) |
9th Aug 2023 8:21am |
tbh with the gearbox feeling thuddy, in my head am budgetting in a replacement/rebuild already. Its actually a sport
9th Aug 2023 8:28am |
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 |
There are other ways to hasten a MiL's demise. |
9th Aug 2023 8:29am |
Fluid change and software update can help but depends on the severity of the harsh changes. Also if it's a crude remap it won't play well with the gearbox programing. 2012 TDV8 Vogue (L322) |
9th Aug 2023 8:33am |
had a full flush recently thanks to Bodsy.
9th Aug 2023 8:55am |
Byg Nyge Member Since: 31 Dec 2022 Location: Newcastle Upon Tyne Posts: 31 |
If its just a thud when putting into drive I'd suspect one of the several prop shaft joints, had the same on a Nissan Navara, it was the rear prop shaft U/J, later the same when a front prop shaft U/J spat the dummy out. |
10th Aug 2023 1:02pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Press on the brake pedal harder before shifting into D. See if that makes a difference Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
10th Aug 2023 4:08pm |
huh that seems like a easy enough to do. will give that a shot thanks
11th Aug 2023 9:05am |
