Home > Maintenance & Mods (L322) > Driver seat bolster
drphilgarner
United Kingdom 2011 Range Rover Vogue 4.4 V8 Buckingham Blue
Driver seat bolster
I've seen this mentioned in buyer's guides so it can't just be mine - there's not enough support on the door side seat bolster in my 2010 4.4. It looks smart enough for its 108k miles, certainly better than many other used examples I've seen online.
Is there any fairly economical repair to restore the padding in the bolster? I assume this would involve taking the seat out and giving it to a trimmer? Has anyone done this with any success?
Post #663305 2nd May 2023 5:48pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Some useful information can be found here: https://www.fullfatrr.com/forum/post396593.html#396593
I’m thinking of doing a repair & swap later in the summer. Probably take both seats out to allow work on them indoors.
P.S. this is a good site I found for colour matched leather repair products should you need them. ( I’ve not used them yet so can’t vouch for their effectiveness or quality. )
https://www.furnitureclinic.co.uk/colour-c...lour-chart TDV8 4.4 2012
Post #663326 2nd May 2023 10:18pm
drphilgarner
Great thanks, I did search but obviously not for the right thing.
Post #663333 3rd May 2023 7:31am
Furniture Clinic products are excellent, used them for years...
Make sure you use adhesion promoter first and get some CrosslinkerX to add to the paint and finish, it will last much longer using it, it's basically a two pack hardener so you have to throw away what you don't use, the professional trim guys don't use it to save waste so your job will be better than theirs...
Make sure you clean the leather well first, Cillit Bang and a scrubbing brush works well, you can be quite vicious with it but it must be very clean, you can even sand it down with 320 dry...
You can dab it with a sponge to get it on but spraying is much better, if you don't have spray equipment a cheap airbrush will do the job. Adhesion promoter, then colour, then Leather finish (I use satin) wait a week and then leather feed, a lot say it won't penetrate painted leather but I found it helps... Thumbs Up Pete
Post #663338 3rd May 2023 8:04am
DrRob
I’ve bought a new seat base foam and associated pads for my 2011 4.4 Tdv8 Vogue SE.
Drivers bolster has softened over the years so decided to renew it. Robin at Duckworths sourced the lot. Not cheap but once I find a RR experienced trimmer it should look brand new. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #663355 3rd May 2023 10:23am
drphilgarner
Looks like Rimmer Bros sell the bolster, then I just need to find someone to take on the job
https://rimmerbros.com/Item--i-HGB500032
Post #663453 4th May 2023 6:23pm
DrRob
Triple check against your VIN before ordering 👍 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #663454 4th May 2023 6:26pm
