Home > Technical (L322) > Transfer Case Surprise...
krzysmaxi
United Kingdom 2011 Range Rover SE TDV8 Alaska White
Well, the time has come to rebuild the transfer case. (I will put separate thread out with pictures)
However... there was a surprise inside...
Does anyone have spare transfer case diff?
Post #663246 1st May 2023 11:09pm
Fatboy Slim
United Kingdom 2008 Range Rover Vogue TDV8 Zermatt Silver
Oh dear! Shocked
Post #663317 2nd May 2023 8:18pm
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
certainly time to have a look at it, I assume it wasn't working too well.
Post #663346 3rd May 2023 9:28am
krzysmaxi
I've posted thread about issues related to transmission some time ago:
https://www.fullfatrr.com/forum/topic63387.html
I hope TC rebuild will solve the problems I had.
I'll post and update once I fit rebuilt unit.
Post #663432 4th May 2023 3:49pm
krzysmaxi
Story progresses:
I brought second hand TC to get some parts from it, or make one good one out of the two.
From outside looked the same. Numbers on casings were the same on the bigger part. The smaller casing with ITC sign - one had number one not.
When opened the one I just brought, result is:
1. One casing has chain slider the other doesn't. Chain length is the same
2. Drive shaft in mine had shim(thick washer) on the purchased one two Bellville springs.
Are these different transfer cases? or just slight differences in their evolution through out years?
Is one better than the other?
Post #663882 11th May 2023 5:05pm
pcourtney
has it been off the road for 12 months then ( since you first mentioned the problem on the forum)
Post #663885 11th May 2023 5:33pm
krzysmaxi
No... but the damage of the centre differential is unrelated. I had another TC fitted.
Post #663894 11th May 2023 6:43pm
RRPhil
Very interested to see the differences. I guess that, as the DD295 transfer box has been in production for nearly 20 years now, there will have been some changes/improvements made over the years. Can you see a Land Rover part number on the casings at all?
Phil
Post #663943 12th May 2023 12:19pm
