Home > Technical (L322) > strange gearbox question
johnboyairey
I’ve had a couple of cars with a linkage issue, mainly rust in the cable assembly.. it might be an easy fix, to just cycle the action with some grease applied to the rod, over and over, to get it sliding more freely. Last car need it dismantling and sanded and lubed… and I also bought a car with a ‘dead gearbox’, diagnosed by bmw sealer…which was actually a snapped linkage, which was an easy fix! It might look like it’s working ok, but the cable might be slightly binding and not allowing full travel.
Post #660108 23rd Mar 2023 10:40am
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
With regard to the fault code for the throttle position sensor, try taking the throttle assembly apart and cleaning inside with carburetor cleaner first, as carbon can seriously build up if one does only short journeys.
Post #660119 23rd Mar 2023 12:47pm
joninprague
Morning all, so I ran a few tests both at idle and also some revs applied. Can anyone see any anomalies that could help me focus in on the lack of power issues?
Thanks in advance
LANDROVER_EN_TEST_00006>Range Rover>2007-2009>Diesel V8>Smart Scan>Diesel V8>View Data:
Total Frames: 15 , Supported Items: 6
Frame 1/15:
Air flow rate from mass air flow sensor - BANK 1 ----- 11.01g/s
Air flow rate from mass air flow sensor - BANK 2 ----- 13.36g/s
Exhaust gas recirculation valve position - BANK 1 ----- 7.84%
Exhaust gas recirculation valve position - BANK 2 ----- 5.88%
Commanded boost actuator control - BANK 1 ----- 76.47%
Commanded boost actuator control - BANK 2 ----- 78.04%
Frame 2/15:
Air flow rate from mass air flow sensor - BANK 1 ----- 12.64g/s
Air flow rate from mass air flow sensor - BANK 2 ----- 26.22g/s
Exhaust gas recirculation valve position - BANK 1 ----- 8.24%
Exhaust gas recirculation valve position - BANK 2 ----- 13.73%
Commanded boost actuator control - BANK 1 ----- 65.10%
Commanded boost actuator control - BANK 2 ----- 49.41%
Frame 3/15:
Air flow rate from mass air flow sensor - BANK 1 ----- 29.38g/s
Air flow rate from mass air flow sensor - BANK 2 ----- 24.37g/s
Exhaust gas recirculation valve position - BANK 1 ----- 5.88%
Exhaust gas recirculation valve position - BANK 2 ----- 8.24%
Commanded boost actuator control - BANK 1 ----- 46.67%
Commanded boost actuator control - BANK 2 ----- 77.65%
Frame 4/15:
Air flow rate from mass air flow sensor - BANK 1 ----- 25.59g/s
Air flow rate from mass air flow sensor - BANK 2 ----- 15.40g/s
Exhaust gas recirculation valve position - BANK 1 ----- 4.31%
Exhaust gas recirculation valve position - BANK 2 ----- 6.27%
Commanded boost actuator control - BANK 1 ----- 78.04%
Frame 5/15:
Air flow rate from mass air flow sensor - BANK 1 ----- 10.81g/s
Air flow rate from mass air flow sensor - BANK 2 ----- 12.75g/s
Exhaust gas recirculation valve position - BANK 1 ----- 7.06%
Exhaust gas recirculation valve position - BANK 2 ----- 7.45%
Frame 6/15:
Air flow rate from mass air flow sensor - BANK 1 ----- 11.73g/s
Air flow rate from mass air flow sensor - BANK 2 ----- 26.63g/s
Exhaust gas recirculation valve position - BANK 1 ----- 9.41%
Exhaust gas recirculation valve position - BANK 2 ----- 9.41%
Commanded boost actuator control - BANK 1 ----- 78.43%
Commanded boost actuator control - BANK 2 ----- 73.33%
Frame 7/15:
Air flow rate from mass air flow sensor - BANK 2 ----- 17.84g/s
Exhaust gas recirculation valve position - BANK 1 ----- 6.67%
Exhaust gas recirculation valve position - BANK 2 ----- 9.80%
Frame 8/15:
Air flow rate from mass air flow sensor - BANK 1 ----- 11.11g/s
Exhaust gas recirculation valve position - BANK 1 ----- 10.59%
Exhaust gas recirculation valve position - BANK 2 ----- 10.98%
Frame 9/15:
Air flow rate from mass air flow sensor - BANK 1 ----- 11.52g/s
Air flow rate from mass air flow sensor - BANK 2 ----- 12.85g/s
Exhaust gas recirculation valve position - BANK 1 ----- 11.76%
Exhaust gas recirculation valve position - BANK 2 ----- 11.76%
Frame 10/15:
Air flow rate from mass air flow sensor - BANK 1 ----- 11.42g/s
Air flow rate from mass air flow sensor - BANK 2 ----- 12.54g/s
Exhaust gas recirculation valve position - BANK 1 ----- 12.94%
Exhaust gas recirculation valve position - BANK 2 ----- 12.94%
Frame 11/15:
Exhaust gas recirculation valve position - BANK 1 ----- 14.90%
Exhaust gas recirculation valve position - BANK 2 ----- 15.69%
Frame 12/15:
Exhaust gas recirculation valve position - BANK 1 ----- 16.08%
Exhaust gas recirculation valve position - BANK 2 ----- 16.47%
Frame 13/15:
Air flow rate from mass air flow sensor - BANK 1 ----- 10.91g/s
Air flow rate from mass air flow sensor - BANK 2 ----- 12.24g/s
Exhaust gas recirculation valve position - BANK 1 ----- 17.65%
Exhaust gas recirculation valve position - BANK 2 ----- 17.65%
Frame 14/15:
Exhaust gas recirculation valve position - BANK 1 ----- 18.04%
Exhaust gas recirculation valve position - BANK 2 ----- 6.67%
Commanded boost actuator control - BANK 1 ----- 68.24%
Frame 15/15:
Air flow rate from mass air flow sensor - BANK 1 ----- 21.51g/s
Air flow rate from mass air flow sensor - BANK 2 ----- 19.47g/s
Exhaust gas recirculation valve position - BANK 2 ----- 5.49%
Commanded boost actuator control - BANK 1 ----- 67.45%
Commanded boost actuator control - BANK 2 ----- 44.71%
Post #660217 24th Mar 2023 10:33am
joninprague
Date(D/M/Y):24/03/2023
LANDROVER_EN_TEST_00008>Range Rover>2007-2009>Diesel V8>Smart Scan>Diesel V8>View Data:
Total Frames: 27 , Supported Items: 2
Frame 1/27:
Exhaust gas recirculation valve position - BANK 1 ----- 10.98%
Exhaust gas recirculation valve position - BANK 2 ----- 14.51%
Frame 2/27:
Exhaust gas recirculation valve position - BANK 1 ----- 14.51%
Frame 3/27:
Exhaust gas recirculation valve position - BANK 1 ----- 16.86%
Exhaust gas recirculation valve position - BANK 2 ----- 16.86%
Frame 4/27:
Exhaust gas recirculation valve position - BANK 1 ----- 17.25%
Exhaust gas recirculation valve position - BANK 2 ----- 18.43%
Frame 5/27:
Exhaust gas recirculation valve position - BANK 1 ----- 18.82%
Exhaust gas recirculation valve position - BANK 2 ----- 21.57%
Frame 6/27:
Exhaust gas recirculation valve position - BANK 1 ----- 22.75%
Exhaust gas recirculation valve position - BANK 2 ----- 23.14%
Frame 7/27:
Exhaust gas recirculation valve position - BANK 1 ----- 23.53%
Exhaust gas recirculation valve position - BANK 2 ----- 36.08%
Frame 8/27:
Exhaust gas recirculation valve position - BANK 1 ----- 7.45%
Exhaust gas recirculation valve position - BANK 2 ----- 5.10%
Frame 9/27:
Exhaust gas recirculation valve position - BANK 1 ----- 5.10%
Exhaust gas recirculation valve position - BANK 2 ----- 3.92%
Frame 10/27:
Exhaust gas recirculation valve position - BANK 1 ----- 9.02%
Exhaust gas recirculation valve position - BANK 2 ----- 4.71%
Frame 11/27:
Exhaust gas recirculation valve position - BANK 1 ----- 4.71%
Frame 12/27:
Frame 13/27:
Exhaust gas recirculation valve position - BANK 1 ----- 8.63%
Frame 14/27:
Frame 15/27:
Exhaust gas recirculation valve position - BANK 1 ----- 12.16%
Exhaust gas recirculation valve position - BANK 2 ----- 11.37%
Frame 16/27:
Frame 17/27:
Exhaust gas recirculation valve position - BANK 2 ----- 30.98%
Frame 18/27:
Exhaust gas recirculation valve position - BANK 1 ----- 30.98%
Exhaust gas recirculation valve position - BANK 2 ----- 30.59%
Frame 19/27:
Exhaust gas recirculation valve position - BANK 2 ----- 33.33%
Frame 20/27:
Exhaust gas recirculation valve position - BANK 1 ----- 30.20%
Exhaust gas recirculation valve position - BANK 2 ----- 31.76%
Frame 21/27:
Exhaust gas recirculation valve position - BANK 1 ----- 33.33%
Frame 22/27:
Exhaust gas recirculation valve position - BANK 1 ----- 31.37%
Exhaust gas recirculation valve position - BANK 2 ----- 34.51%
Frame 23/27:
Exhaust gas recirculation valve position - BANK 1 ----- 32.16%
Exhaust gas recirculation valve position - BANK 2 ----- 32.55%
Frame 24/27:
Exhaust gas recirculation valve position - BANK 1 ----- 34.12%
Exhaust gas recirculation valve position - BANK 2 ----- 34.12%
Frame 25/27:
Exhaust gas recirculation valve position - BANK 1 ----- 32.55%
Frame 26/27:
Exhaust gas recirculation valve position - BANK 2 ----- 33.73%
Frame 27/27:
Exhaust gas recirculation valve position - BANK 1 ----- 33.73%
Exhaust gas recirculation valve position - BANK 2 ----- 32.94%
Total Frames: 26 , Supported Items: 2
Frame 1/26:
Frame 2/26:
Frame 3/26:
Frame 4/26:
Frame 5/26:
Frame 6/26:
Commanded boost actuator control - BANK 2 ----- 77.25%
Frame 7/26:
Commanded boost actuator control - BANK 1 ----- 70.20%
Commanded boost actuator control - BANK 2 ----- 58.82%
Frame 8/26:
Commanded boost actuator control - BANK 1 ----- 57.25%
Commanded boost actuator control - BANK 2 ----- 55.69%
Frame 9/26:
Commanded boost actuator control - BANK 1 ----- 54.51%
Commanded boost actuator control - BANK 2 ----- 52.55%
Frame 10/26:
Commanded boost actuator control - BANK 1 ----- 52.55%
Commanded boost actuator control - BANK 2 ----- 52.16%
Frame 11/26:
Commanded boost actuator control - BANK 1 ----- 51.37%
Commanded boost actuator control - BANK 2 ----- 51.37%
Frame 12/26:
Commanded boost actuator control - BANK 2 ----- 48.24%
Frame 13/26:
Commanded boost actuator control - BANK 1 ----- 59.61%
Commanded boost actuator control - BANK 2 ----- 56.47%
Frame 14/26:
Commanded boost actuator control - BANK 1 ----- 52.94%
Frame 15/26:
Commanded boost actuator control - BANK 1 ----- 44.31%
Commanded boost actuator control - BANK 2 ----- 47.84%
Frame 16/26:
Commanded boost actuator control - BANK 1 ----- 43.53%
Commanded boost actuator control - BANK 2 ----- 61.96%
Frame 17/26:
Frame 18/26:
Frame 19/26:
Frame 20/26:
Frame 21/26:
Frame 22/26:
Frame 23/26:
Frame 24/26:
Frame 25/26:
Frame 26/26:
Post #660218 24th Mar 2023 10:35am
joninprague
Thanks so much. It was the linkage and the gearbox stays in gear now although sometimes the keys dont want to come out of the ignition when in Park so perhaps needs some adjustment. Smile
Post #660219 24th Mar 2023 10:37am
