Home > Technical (L322) > L322 4.4 TD 2011 Thermostat Housing |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3203 |
Where is it cracked? My garage managed to source the lower part before supplies ran out but the upper part is non existent...... 2012 TDV8 Vogue (L322) |
24th Feb 2023 3:33pm |
Alphabatim Member Since: 20 Apr 2021 Location: Anglesey Posts: 5 |
Have just discovered that the part is not called a Thermostat Housing but is
24th Feb 2023 3:45pm |
The top part with the temp sensor ? 2012 TDV8 Vogue (L322) |
24th Feb 2023 3:49pm |
Hi JayGee... Thank you for getting back .The crack is in the lower piece ... any idea where they managed to source it? |
24th Feb 2023 3:52pm |
Where is the crack exactly?
24th Feb 2023 4:17pm |
Its the bottom part .. it was cracked underneath and broke off when removing it ...if I can get a bottom part it would do ... |
24th Feb 2023 4:29pm |
like this?
24th Feb 2023 4:58pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
Try Gentlemen of Salvage I have used them for hard to find bits for my p38 and a diff for my l322 |
25th Feb 2023 7:45am |
If you are going for a used part get one from a later L405 SDV8 as the plastic will still be in good condition. 2012 TDV8 Vogue (L322) |
25th Feb 2023 12:23pm |
As J said get the newest you can and order the new part but at least it will get you going till it arrives I have had to do it a couple of times |
25th Feb 2023 6:07pm |
25th Feb 2023 6:08pm |
Thank you for replying and yes that is the issue exactly… I will follow up on both your suggestions… like the idea of used one as temporary solution…have called a number of dealers in Ireland but same problem.. will try France Next! |
25th Feb 2023 8:21pm |
