Home > Technical (L322) > L322 4.4 TD 2011 Thermostat Housing
Alphabatim
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Hi all
I am looking for some help! I need a replacement Thermostat Housing for a Range Rover Vogue SE 4.4 TD 2011 as original is cracked but they are on back order with Land Rover and long delays. The Unit in question is A FoMoCo branded unit. Would anyone know where I could source one or if this unit was used on any other vehicle such as Ford or BMW ?
Any advice or suggestions much appreciated.
Post #657643 24th Feb 2023 1:58pm
JayGee
Where is it cracked? My garage managed to source the lower part before supplies ran out but the upper part is non existent...... 2012 TDV8 Vogue (L322)
Post #657657 24th Feb 2023 3:33pm
Alphabatim
L322 4.4 TD 2011 Thermostat Housing / Water Outlet
Have just discovered that the part is not called a Thermostat Housing but is
a Water Outlet Part No. LR110459....
Post #657658 24th Feb 2023 3:45pm
JayGee
The top part with the temp sensor ? 2012 TDV8 Vogue (L322)
Post #657659 24th Feb 2023 3:49pm
Alphabatim
Hi JayGee... Thank you for getting back .The crack is in the lower piece ... any idea where they managed to source it?
Post #657661 24th Feb 2023 3:52pm
JayGee
Where is the crack exactly?
The lower part which contains (the thermostat) had been on back order since Dec but i also needed the upper part as the bleed hose connector had broken during removal - I made the part myself otherwise I'd still be waiting now..... 2012 TDV8 Vogue (L322)
Post #657663 24th Feb 2023 4:17pm
Alphabatim
Its the bottom part .. it was cracked underneath and broke off when removing it ...if I can get a bottom part it would do ...
Post #657667 24th Feb 2023 4:29pm
JayGee
like this?
Post #657669 24th Feb 2023 4:58pm
Sandyt
Try Gentlemen of Salvage I have used them for hard to find bits for my p38 and a diff for my l322
Post #657704 25th Feb 2023 7:45am
JayGee
If you are going for a used part get one from a later L405 SDV8 as the plastic will still be in good condition. 2012 TDV8 Vogue (L322)
Post #657727 25th Feb 2023 12:23pm
Sandyt
As J said get the newest you can and order the new part but at least it will get you going till it arrives I have had to do it a couple of times Thumbs Up
Post #657788 25th Feb 2023 6:07pm
Sandyt
Post #657789 25th Feb 2023 6:08pm
Alphabatim
Thank you for replying and yes that is the issue exactly… I will follow up on both your suggestions… like the idea of used one as temporary solution…have called a number of dealers in Ireland but same problem.. will try France Next!
Post #657811 25th Feb 2023 8:21pm
