![]() | Home > Technical (L322) > Battery flat and Emergency key won’t unlock the door |
Grundey2 Member Since: 03 Jan 2023 Location: Lincolnshire Posts: 31 ![]() ![]() ![]() |
It’s a 2010 4.4 TDV8 |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
spot on James that must have been a bit of a scruff to get to. at the moment I am putting in a live feed from the main battery running 10 mm cables to go behind the front bumper so you can get to them from the lower vent wear the washer bottle is just flip out the vent and you will have direct power hook up so you can energize the main battery. I have already installed a second battery in the back but if the main battery in the engine bay goes down there is no power to energize the 100 am relay on the second backup battery in the back so you need to get 12 volts to switch the back up when you turn the ignition key things you have to do just to get in . it might be time to get another horse bit of hay some oats and a bucket of water job done new vehicle purchase
I’ll also be adding a fly lead incase it ever happens again.
