Removing injectors on 4.2 sc engine with 206/216/306/316 | |
My 2008 is showing several codes Re misfires P0306 316 206 216 which relates to injector 6 circuit A. I am asking if anyone has done a home non dismantle injector cleaning if they have had this code. It’s 8 plus hours by the book to get at the injectors, (Re and Re) and probably a lot longer for me. I do need to change some hoses and pulleys on the front also but it would be nice to get it running. I’ve put in a new coil to no effect and I had pulled the plug to have a look at it looked typical but not steam cleaned. I have the fuel line removal tool which works but I can’t figure out how to unplug the injector harness from the main harness. I have pulled back the red clip but the plug does not come apart. I would really like to know that secret. Everything else seems doable but daunting. And when apart can I test the circuit with a noid light with so much disassembled on the engine as there seems to be no way to access the injector harness for that injector afaik as the wires are short and underneath the intercooler. Many thanks
