Home > Technical (L322) > Removing crankcase pulley
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
So whilst swapping the viscous fan I noticed oil on the front of the engine which looks like it’s from the crankshaft oil seal, so whilst attempting to shift the nut with a 4’ breaker bar I ended up breaking the pulley and not undoing the nut 🙄😡 I had been told it’s a standard thread but on a stretch bolt so undoing it anti clockwise I’m hoping this is correct, has anyone done this and how did you get the bolt out then the oil seal, I now need to add to the list a new crankshaft pulley 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #648557 19th Nov 2022 5:22pm
Furnitureman
UPDATE
Using my boys rattle gun I got the nut out it is a standard thread, but out damaged pulley off to find this
Think this is the culprit
Can clearly see signs of wear on the oil seal so new one to be ordered 2012 Range Rover Westminster 4.4 TDV8
Post #648611 20th Nov 2022 10:53am
