![]() | Home > Technical (L322) > MOT Time |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 816 ![]() ![]() |
What were the advisories, and what mileage has the old girl done ? |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
I got advisories for 'chips in windscreen' and 'suspension component rust'. When challenged, the guy showed me a minute windscreen chip not in the driver's field of view. And they said the suspension component was surface rust on the chassis, so to just wire brush it off. The guy remarked "you'd struggle not to find a chassis with surface rust on vehicles older than about 5 years".
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
I do sometimes wonder If they just add something for their justification?.
I was impressed by how mine passed with minimum issues. I’d be more impressed if like some other counties we had dedicated gov run testing stations and not garages with licences to test. 2012 TDV8 Vogue (L322) |
I think many hundreds of thousands of instances where the garage are friendly with the owners of the car would end up failing! 2015 Range Rover Autobiography 4.4 SDV8 |
I bought mine with 11 months MOT and it was literally unbelievable it had passed. Likely due to a ‘friendly’ MOT tester…… 2012 TDV8 Vogue (L322) |
An 'advisory' is something the tester has noticed that is not a minor defect but may become one (or a major defect).
landy95 Member Since: 04 Aug 2021 Location: Hall Green, West Midlands Posts: 79 ![]() ![]() ![]() |
I forgot to remove my dash cam and got an advisory for it, he removed it and passed the mot, thats a bit OTT if you ask me. Also own a 1976 Land Rover 101 3.5 V8.
Probably because it was obscuring the field of view?
Depends where on the screen it was, if within the area swept by the wipers - and therefore considered to be in the drivers field of view, an 'advisory' to let you know it's potentially obstructing your view of the road would be correctly given. |
That's 'Jobsworth of the year award' territory....... 2012 TDV8 Vogue (L322) |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1356 ![]() ![]() |
Its what vosa likes to see though, they don't want to see a test station just passing through lots of vehicles with pass certs without advisories and want to see a proportionate number of failures too.
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
just the 2 grease on brake lines. she has done 135k 2012 Vogue 4.4 TDV8 - Current 2014 Navara V6 - Gone 2004 Vogue TD6 - Gone Grand Cherokee - Gone Discovery V8 (LPG) - Gone Discovery TD5 - Gone |
