Home > Technical (L405) > L405 5.0 - Whining sound from wheel area + engine sound
RangeRov
Sweden
Hi all,
I just went to see an 5.0 L405 and need your help to confirm if the engine sound healthy and correct and what the whining sound from the tire area is?
My impression was that engine sound was different on each side of the engine, I do know lifters sounds on V8s (Had amg 6.2 in the past) but as I have never heard the 5.0 supercharger before I am not sure if it is all good.
Whining sound 1 = https://youtube.com/shorts/ehHng72oO7Q
Whining sound 2 = https://youtube.com/shorts/n48SXW2zBsk
Engine start up =
Engine sound 1 = https://youtube.com/shorts/jtiCtGDEc1w
Engine sound 2 = https://youtube.com/shorts/kZENRzDI1cg
There is a leakage of the exhaust system but I dont know if that is generating the whining sound.
All input is of interest as I need to bid during this weekend.
Exhaust leak picture = https://drive.google.com/file/d/1FDqAxufAj...sp=sharing
Post #647883 11th Nov 2022 11:03am
RangeRov
Sweden
No one?
All help needed Bow down
Post #647925 11th Nov 2022 10:05pm
My 2p....
Can't hear a whining sound on the first two, very difficult to hear stuff recorded on a phone...
The engine ones sound about right, the 5.0 S/C doesn't sound very nice on tickover, more like a diesel than a petrol, well mine did anyway, can't hear any timing chain rattle on it...!! Pete
Post #647932 11th Nov 2022 11:34pm
RangeRov
Sweden
Thank you for your input!
On the second video, Whining sound 2 = https://youtube.com/shorts/n48SXW2zBsk It sounds like an air leakage that is increasing when I walk from the back to the front which is what I am concerned about.
Post #647938 12th Nov 2022 8:37am
If it's got an air suspension leak you can hear whilst stationary then it should drop with the engine off...
Lift the boot floor and listen for the compressor, if it's constantly on then you have a leak, it should overheat, cut off and throw a fault code, this usually doesn't take much time.... Pete
Post #647951 12th Nov 2022 12:03pm
