Home > Technical (L322) > 4.4 TDV8 Catalytic Converter
Andrewb94
Hi everyone, I could really use some help!
Took my 2011 4.4 TDV8 to a mechanic for some suspension work, and they said my catalytic converter had been cut open and welded, suspecting it had been gutted/tampered with.
I believe the cat is on the drivers side in front of the DPF.
I’m trying to look at photos of the cat online and the ones I found also had a weld line down the centre.
Does anyone know if this is how they come from the factory?
Thanks so much.
Post #642332 8th Sep 2022 7:57am
garyRR
Yes, they have a thick weld line down the centre from factory iirc.
The ones on the 3.6 TDV8 do too. 2015 Range Rover Autobiography 4.4 SDV8
Post #642346 8th Sep 2022 10:58am
They all have a weld sir... That said, post up a picture of yours and maybe that will be more definate?
Post #642355 8th Sep 2022 12:31pm
Andrewb94
Thanks everyone!
Turns out the cat was empty. I knew DPFs are sometimes gutted and put back but I didn’t think anyone would mess with the cat.
Post #642365 8th Sep 2022 2:05pm
JayGee
I'd check the DPF as well.... 2012 TDV8 Vogue (L322)
Post #642366 8th Sep 2022 2:10pm
Andrewb94
Good call, thanks!
Post #642383 8th Sep 2022 4:33pm
