Home > Technical (L322) > Further digging with diagnostics reveals PO62F |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1465 |
A few things. It's very rare for the ZF transmission to encounter any issues so my first point of call would actually be the battery:
6th Sep 2022 7:53am |
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 99 |
Re fault code being symptom not cause I agree totally hence trying to find the cause , first happened late last week when I went to move it to start doing rear toe arms , new battery (Bosch silver ) in June , battery was disconnected over weekend whilst I was doing rear arms (had ride height sensors off hence battery disconnect) but EML came on before battery disconnect , doesn't do many short journeys and was away over BH weekend before it happened so plenty of long distance miles , completely out of blue hence being slightly confused , gearbox oil was changed about 3 years ago and Ravenol 8 was used (weekend/nice car rather than runabout hence not stupid miles a year , 22 yrold 200k+ miles Disco is runabout/works van ), slightly concerned re eprom fault and looking for any ideas . |
6th Sep 2022 8:53am |
If the battery is new, have you checked the voltage? A new battery doesn't necessarily mean it's being charged properly (or corroded terminals / cables) and the 4.4 TDV8 is well known for alternator issues. Also, as far as I know, a standard Bosch silver isn't an AGM battery unless it's the S5A13.
6th Sep 2022 9:01am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3068 |
What code reader are you using?
6th Sep 2022 9:16am |
Delphi DS1e diagnostics , from reading through settings on freeze frame battery voltages are good , couple of odd temp readings , that aside fired it up this morning and no issues , took it for a spin and all was fine , will keep monitoring and see how it goes , hopefully just a glitch but we are all a little paranoid re these cars , especially our own , it's the silly expensive AGM Bosch battery btw not the normal silver one .
6th Sep 2022 10:23pm |
