Home > Maintenance & Mods (L322) > Washer Jet Upgrade - Fan Spray |
No - so the plan is to sort something by winter, maybe see what heated options there are... What I find is that because the washer jet pipes run along the bonnet grille, they get frozen unless I use a super strong mix. I do a fair amount of fast driving and I think this leads to a significant wind chill across the pipes. This section is also cut off from the engine bay as it's behind the firewall so gets no heat. I plan to lag the pipes with some of the foil backed foam or something fairly thin. |
14th May 2011 11:43pm |
I think the tank is OK as long as there is anti-freeze in there, plus it sloshes about. But the pipes are so small they easily freeze I think. When they are frozen, the heated washer nozzles are academic really. |
16th May 2011 2:49pm |
allisong Member Since: 28 Jun 2011 Location: UK Posts: 9 |
I have just fitted the BMW E63 washer jets and they work fine, they fit in the same hole (have to push them in) and the hoses need lengthening as the connectors on the new washer jets are straight down instead of a right angle. The BMW part number is: 61667054446
21st Mar 2012 10:01am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35278 |
good info , thanks.. ... - .- -.
21st Mar 2012 10:34am |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
@Allisong, any chance of a video clip to show them in action? (at a standstill not at 90 ) |
22nd Mar 2012 11:33am |
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 |
Apologies for getting an old tread going but did anyone ever get a definitive outcome with this, i too would love to have a fan spray rather than the old jets but until i found this tread by accident never thought it was possible.
3rd Mar 2014 2:43pm |
3rd Mar 2014 5:44pm |
That was for a 2007 TDV8, not sure its the same on a BMW based 2002 TD6 |
3rd Mar 2014 6:14pm |
docjones Member Since: 22 May 2013 Location: Helsinki Posts: 48 |
So has anyone else done this mod? Any pictures/videos?
16th Dec 2014 9:42am |
