Home > Technical (L322) > Air Suspension - Gallery Pressure Won’t Reduce |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Sounds like the front valve block isn't venting to gallery - has the pipe been pinched? if the valve block was disconnected it should throw a DTC or two. |
13th Aug 2022 4:06pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3074 |
The front valve block is right down at the bottom behind splash guards, I’ve not been near that one so am a bit confused by it.
13th Aug 2022 4:11pm |
Are the height sensors OK? - as in link rods connected and nothing stopping free movement? |
13th Aug 2022 4:30pm |
Also, have you got the blue & black pipes in the correct positions on the reservoir block?
13th Aug 2022 4:43pm |
Sorted
13th Aug 2022 4:51pm |
Odd how it was venting the rears and not the front though! |
13th Aug 2022 4:58pm |
Indeed. Very strange.
13th Aug 2022 8:18pm |
A few years ago i had a L319 that had dessicant in the front valve block, nowhere else, it caused all kind of issues - of course, no helpful DTC's were set... I tried cleaning the block (easy enough to open up) but the bore was scored so it was never working 100% after that. Out of warranty so the customer had to stump up for a new valve block & filter/drier, we recommended a new airline but I think the labour cost to change killed that idea! |
13th Aug 2022 8:25pm |
