Home > Technical (L322) > Aircon problem |
Paddocks67 Member Since: 17 Apr 2020 Location: Glasgow Posts: 28 |
Cheers for the replies phoenix, thanks again mate,pat |
26th Jun 2022 8:12am |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
It's not the pressure, which is temperature dependent, it's the charge weight - shown on the slam panel or the bonnet label, I forget which. How did you evacuate the system prior to changing the pipe?
10th Jul 2022 8:37pm |
I never evacuated the system,I just unscrewed the pipe and pulled it off,Phoenix |
10th Jul 2022 9:06pm |
Right, then can I suggest that you get it booked in to somewhere that does an aircon degas / regas so they can suck out whatever remains in your system, vac. it out to remove any traces of oxygen (and leak check it) then charges with the correct amount of refrigerant?
10th Jul 2022 9:25pm |
Cheers Phoenix,I will get it checked into a aircon shop,pat |
10th Jul 2022 10:05pm |
At least you now have a plausible pressure reading, so that's a step forward! |
10th Jul 2022 10:20pm |
10th Jul 2022 10:21pm |
Definitely Phoenix,I'll get it working yet,haha |
10th Jul 2022 10:22pm |
A Man after my own heart - if it's there, it has to work properly! That principle has cost me dear... |
10th Jul 2022 10:25pm |
