Home > Technical (L322) > Recirculated air - where is it drawn from? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
Most I have seen have said to put the can in the rear footwell and leave the doors closed and HVAC on recirc for around 15mins... I had a smelly car once and put it in the front foot well pointed up towards the bulkhead which is where, I believe, the recirc draws air from, and the car stunk of the cleaner for weeks...
10th Jul 2022 9:21am |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
I've been through Topix again, still no real clue although I do agree that it has to be at the sides of the heater box as that's where the actuator & flaps are. I think I'm going to take the centre side cheeks off in the footwells and point a can each side up the side of the heater box with the fan on 50%, recirc. on manual, distribution manually set to 'everything' and the temp on whatever the ambient is, that way it'll clean both the heat exchanger and the evaporator. Yep, it'll smell a bit 'chemical' for a few days but it'll be better than the current smell which is as mixture of 'stale cigar smoke' and 'child'...
10th Jul 2022 3:58pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
It's drawn from the pollen filter housing behind the glove box.
10th Jul 2022 8:51pm |
L322 not L405 matey! |
10th Jul 2022 9:31pm |
Whoops! Sorry! Kev
10th Jul 2022 10:07pm |
No worries - it does get a bit confusing sometimes as there is so much crossover. |
10th Jul 2022 10:18pm |
